FME Form: 2026.3
Publishing to FME Flow
Note  To publish workspace templates to FME Flow, see Saving a Workspace as a Template.
Open the workspace you want to publish. Click Deploy > Publish to FME Flow..., or click the button on the FME Workbench toolbar.
The Publish to FME Flow wizard opens. Proceed through the panels of the wizard:
  1. Publish a Workspace, Transformer, or Custom Format
  2. Upload Connections
  3. Upload Packages
  4. Register Services
Note  To publish to FME Flow, you must have a deployment of FME Flow configured and available. For information, contact your System Administrator.
Publishing from FME Form to FME Flow When Versions Do Not Match
For best results, the versions of FME Workbench and FME Flow should match. Publishing a workspace from FME Workbench to FME Flow is supported if the year and major version (for example, 2024.1) match, and the remainder of the version of FME Workbench is the same or older than FME Flow.
Warning  When publishing between different versions of FME Workbench and FME Flow, always verify results before proceeding in a production workflow.
Publishing from FME Workbench Version Publishing to FME Flow version Supported?
2024.1 2024.1 Yes (same major version)
2024.1.2 2024.1.3 Yes (same major version)
2024.1 2024.2 No (different major version)
2024.2 2024.1 No (FME Workbench is a newer version than FME Flow.)
2024.1.3 2024.1.2 No (FME Workbench is a newer version than FME Flow.)
See Also
