FME Form: 2026.1
Publishing Templates to FME Flow
One method of distributing your work is to publish it as a template to FME Flow.
Note  To publish to FME Flow, you must have a deployment of FME Flow configured and available. For information, contact your System Administrator.
  1. Open a workspace and select File > Save As Template. The Save as Template dialog opens.
  2. Add information to describe and identify the template. For information on the individual fields in the dialog, see Saving a Workspace as a Template.
  3. Click the Save and Publish button at the bottom of the dialog. The template will be saved, and the Publish to FME Flow wizard will appear.
  4. Specify the connection parameters to the applicable FME Flow, and click the Next button. For more information on the connection parameters, see Publishing to FME Flow.
  5. Follow the remaining instructions in the wizard.
The default Save location is <User>\Documents\FME\Templates\<template_name>.fmwt.
