FME Form: 2026.2
Viewing the Log
From the Menu Bar, select View > Window Layout > Translation Log.
The translation log pane displays statistics and processing information that includes the following:
  • FME version
  • Reader being used
  • Writer being used
  • Logging information
  • Warning messages
  • Command line, including user parameters
  • A link to the workspace performance profile, if enabled.
The Log window contains a toolbar that provides the following functions:
  • Edit log file settings in Utilities > Options > Translation.
  • Filter messages based on Log Message Types (see below).
  • Wrap the text around the Log window.
  • Display or hide line numbers.
  • Find text.
  • Find next instance of text that was previously searched in "Find text".
You can also right-click inside the log window and copy selected contents of the window directly to another application, or save the contents to a text file.
Log Message Types
The log file is an important record of a translation and all the stages and processes within it. At first glance it might appear complex, even for a successful translation, but the information in here can be helpful when the output is not what was expected.
Tip  To produce more detailed logs for troubleshooting, run translations in Log Debug mode.
ERRORs
An ERROR in the log window signifies a problem that has caused FME to terminate processing. A typical example would be the inability to write the output dataset. It could just be that the user permissions are not correct, but since FME cannot create an output, there is no need to continue.
WARNings
A warning in the log window (displayed as WARN) signifies that there is a problem in the processing. The problem was not sufficient to cause FME to terminate the process, but you’ll want to check that the problem has not adversely affected your output. For example, features with an incompatible geometry for the destination Feature Type will not cause the process to fail, since FME can filter out these features. However the output will not be what was expected.
INFORMation
An information message (displayed as INFORM) is a non-error incident which signifies a piece of information that may help you determine whether your translation has been correctly processed. Typical information would be the number of features processed or confirmation of a particular setting for that dataset.
STATisticS
Statistics messages (displayed as STATS) provide information on the number of features read from the source and written to the destination datasets.
Note  The text in this area contains important information about the translation. If you ever get results that you did not expect in your output data, check the contents of the log.
Performance
In general, FME performance can be slowed by the contents of the log window scrolling past. This is especially true when there are many features that all trigger the same warning. Keep the log window closed or resized to a minimum when running a translation. You can open the window again for inspection after the translation is complete.
Interpreting the Messages
See Interpreting the Log for information on interpreting the contents of the log.
Note  Because some FME functionality is implemented using a third-party library (for example, GeoDatabase writing uses Esri ArcObjects), some information in the log window is reported directly from a product.
See Also
