FME Form: 2025.1
Python Compatibility
Workspace/Transformer Parameters > Scripting > Python Compatibility
This parameter specifies the level of compatibility your workspace or custom transformer has with different versions of the Python programming language, and determines the Python interpreter used by FME when running a workspace.
FME loads a Python interpreter that is either compatible or potentially compatible with this setting. On Windows and macOS, this is a Python 3.13 interpreter bundled with FME, and on Linux, it is the Python interpreter installed on the system.
On Windows, a custom Python interpreter can be used instead of the interpreter bundled with FME by specifying a custom interpreter for the Preferred Python Interpreter setting in Translation. FME will use that interpreter as long as it is compatible or potentially compatible with the workspace's Python Compatibility setting.
Backward Compatibility
- If the workspace does not contain user-defined Python, Python Compatibility automatically updates to the latest supported Python version.
- If the workspace contains user-defined Python, a warning displays to inform you that Python Compatibility will automatically update to the latest supported Python version, which may cause unexpected behavior at workspace runtime.
Custom transformers with Python Compatibility set to Python 2.7 or Esri ArcGIS Python 2.7 must be manually updated to a supported setting before embedding or linking in a workspace.
Compatibility Levels
- Compatible: Python version x.y is compatible with w.z if x == w and y >= z
- Potentially compatible: Python version x.y is potentially compatible to version w.z if x == w and y < z
- Incompatible: Python version x.y is incompatible with version w.z if x != w
Specifying a Compatibility
The table below lists the Python versions and compatibility values in FME Workbench.
| Python version | The workspace or custom transformer is compatible with: | Preferred Python Interpreter Value |
| Python 3.13+ | Python 3.13 and higher | FME Python 3.13+ or a custom interpreter based on Python 3.13 or higher |
| Python 3.12+ | Python 3.12 and higher | FME Python 3.12+ or a custom interpreter based on Python 3.12 or higher |
| Python 3.11+ | Python 3.11 and higher | FME Python 3.11+ or a custom interpreter based on Python 3.11 or higher |
| Python 3.10+ | Python 3.10 and higher | FME Python 3.10+ or a custom interpreter based on Python 3.10 or higher |
| Python 3.9+ | Python 3.9 and higher | FME Python 3.9+ or a custom interpreter based on Python 3.9 or higher |
| Esri ArcGIS Python 3.9+ | Python 3.9 interpreter distributed with ArcGIS Pro 3.0 - 3.2 and ArcGIS Server 11.0 - 11.2 | Esri ArcGIS Python 3.9 |
| Esri ArcGIS Python 3.11 | Python 3.11 interpreter distributed with ArcGIS Pro 3.3 - 3.5 and ArcGIS Server 11.3 - 11.5 | Esri ArcGIS Python 3.11 |
Scenarios
To run a Python-enabled workspace/custom transformer as optimally as possible on FME Form
Leave Python Compatibility at its default setting.
To use a specific Python interpreter, such as a system-specific interpreter with custom modules
Set Python Compatibility to match the Python version of the custom interpreter specified by the Use Custom Interpreter setting of the Preferred Python Interpreter option (Utilities > FME Options > Translation).
To ensure the greatest compatibility with other FME Form users and/or FME Flow.
To use an Esri ArcGIS Python interpreter to make use of the ArcPy package
Set Python Compatibility to an available Esri ArcGIS Python.
