FME Form: 2026.3
AI Assist
The Artificial Intelligence (AI) Assist plugin provides answers to just about any question you may have about working with FME, such as what transformer to use for a certain operation, or how to set the right parameters for a desired result.
When invoked from applicable dialogs, AI Assist can also help you create SQL queries, regular expression search patterns, or Python code.
Getting Started With AI Assist
To use AI Assist requires the following:
  • Enable AI Assist must be checked under Utilities > FME Options > Workbench > AI Assist Options.
  • You must be logged in to your FME account. Click Log In from the AI Assist Window. For more information about FME accounts, see FME Account FAQ.
Note  The following options are available to disable access to AI Assist across your organization:
  • Block access to the https://fme-ai-service.safe.com/ domain.
  • (FME versions 2026.1 and later) Set the machine-level registry key Enable AI Assist to false.
Administering the AI Assist Plugin
At the top right of the AI Assist window, click More. You can:
  • Get the current version of the AI Assist plugin and discover What's New between versions.
  • Manually update to a later version of the AI Assist plugin. Manual upgrades are available if an orange dot appears beside the More button.
  • Enable Automatic Updates: Downloads and installs AI Assist plugin updates in the background, which take effect the next time AI Assist restarts.
  • Get Security, Privacy, and Trust information about using the AI Assist plugin.
Uninstalling
From the FMEFME Workbench menu, select Utilities > FME Options. On the Workbench pane, under AI Assist Options, uncheck Enable AI Assist, and click Uninstall AI Assist Plugin.
Using AI Assist for General Help With FME
Use the AI Assist window to ask for assistance with any aspect of working with FME. This window appears by default. To control its appearance, select or unselect View > Window Layout > AI Assist from the menu bar.
Tips and Tricks
Here are some tips for using AI Assist for general help with FME:
Tailor a question to a specific part of a workspace
Note  To use this feature, the Enable context in the AI chat workspace parameter must be set to Yes.
Before submitting a request, select the objects on which you want to base your inquiry.
Alternatively, click to highlight the AI Assist widget on the mini-toolbar for each item on the canvas on which you want to base your inquiry. For example, for information about how a particular transformer works, highlight its widget on the mini-toolbar, then enter "What does this transformer do?"
Tip  AI Assist keeps track of the number of objects you select for context at the bottom of the AI Assist pane. To clear all selections, click the x:
Add a summary annotation to a workspace
With an open workspace, instruct AI Assist to "Summarize this workspace" (or similar). In the AI Workspace Summary pane that appears, click Add as Annotation.
Add a workspace overview
You can use AI Assist to populate the Overview workspace parameter. With an open workspace, instruct AI Assist to "Summarize this workspace" (or similar). In the AI Workspace Summary pane that appears, click Add to Workspace Description.
Add an object to the canvas
You can ask AI Assist for help in adding objects to the canvas, such as readers, writers, or transformers. For example, to add a JSON reader, enter "Add a JSON reader." A JSON reader widget appears in the AI Assist window. To open the Add Reader dialog for the JSON reader, click Add to Workspace.
Using AI Assist for Help With Code, Queries, and Regular Expressions
When AI Assist is opened from an applicable dialog, you can get help creating SQL queries, regular expression search patterns, or Python code. To open AI Assist from one of these dialogs, click the AI Assist button: .
Pattern
Description
Example FME Workbench Locations
Python
In transformers that support Python code, AI Assist allows you to generate Python from a description, existing code, or a combination of both, and then refine, explain, or add comments to the generated Python code.
PythonCaller,
PythonCreator
RegEx
In parameters that support regular expressions, you can input a description in plain English, and AI Assist will generate a recommended expression to use, and a description of the results.
StringReplacer
SQL
In parameters that support SQL queries, you can input a description of a query in plain English, and AI Assist will generate a recommended SQL Query, and a description of the results.
InlineQuerier
Capabilities and Limitations
When working with AI Assist, keep in mind the following:
  • When AI Assist is open, you can still operate in the dialog from which it was launched. You can work freely between the launch dialog and AI Assist at all times.
  • AI Assist does not remember previous requests to generate code. Each request must be made independently of any previous request.
Generating Python
AI Assist is available in transformers that require Python code. You can Generate Python from a description (plus any existing code), and Refine, Explain, or Add Comments to the generated Python code.
Request
Select an Action from the drop-down list.
Action
Generate Code – Sends a request to generate code based on a combination of input request in the Python Description field and any existing code in the AI Results field.
Refine Code – Refines any existing Python Code. This action is most useful for code that is automatically copied from the Python editor when AI Assist is opened, or code that is manually written or edited directly in AI Assist.
Explain Code – Adds explanations of any existing Python Code to the Explanation section. This action is most useful for code that is automatically copied from the Python editor when AI Assist is opened, or code that is manually written or edited directly in AI Assist.
Add Comments – Adds comments to any existing Python Code.
Python Description
If Action is Generate Code, use this section to describe the requirement in plain English.
For best results:
  • Avoid using complex or technical language. AI prompts work best when they are simple and concise.
  • Provide as much FME-related context as possible, including the name of the application ("FME", "FME Workbench", or "FME Form") and the applicable transformer (for example, "PythonCaller").
  • Send main editor content to AI as context: If checked, and Action is Generate Code, any pre-existing code in the Python editor of the parameters dialog of the corresponding transformer is sent to the AI service along with the contents of Python Description.
Status
Displays the status of the AI Service.
AI Results
Generated results appear in this section.
Feedback Feedback helps us refine our features. To provide feedback on AI Assist, click the "thumb up" or the "thumb down" icon.
When the feedback panel opens, you can enter additional comments.
Explanation
The AI server generates an explanation of the Python code.
Generating RegEx
Regular Expression Description
Use this section to describe the requirement in plain English, and then click the Generate button.
Tip  Avoid using complex or technical language. AI prompts work best when they are simple and concise.
Status
AI Results
Test String
AI Assist will generate strings to test the regular expression. You can also enter your own strings in this section.
Note  Test strings are not sent to the AI service.
Explanation
The AI server generates an explanation of the regular expression.
Generating SQL
In parameters that support SQL queries, AI Assist will generate a recommended SQL Query, and an explanation of the results.
Note  AI Assist is available for SQL queries only if the parameter is associated with a recognized database format in the workspace. For example, if the SQL Query editor is opened from the InlineQuerier parameters dialog, the AI Assist button is visible only when the InlineQuerier recognizes the database format that is queried.
SQL Query Description
  • Send database schema to AI: If checked, the schema of the database you are querying is sent to the AI service along with the query description. Schema information includes relevant metadata about the database, such as table names, column names, and column data types. It does not include any actual data.
    Note  Send database schema to AI helps the AI service tailor the results to your database schema. However, depending on schema complexity, this option may add significant processing time to the request. If not checked, the SQL syntax that is returned may be correct, but will require you to substitute the relevant schema information in the results. For better results if not checked, specify the applicable database format in the SQL Query Description (for example, "Microsoft SQL Server Non-Spatial" or "MSSQL_ADO").
Status
AI Results
Explanation
The AI server generates an explanation of the SQL query.
See Also
