FME Flow: 2026.3
Deploying with Kubernetes and a Trusted Certificate
To deploy FME Flow with a trusted certificate to a Kubernetes cluster, you can run cert-manager in your cluster, which issues the necessary certificates.
Alternatively, you can deploy with a certificate and private key that are already generated.
When finished, connect to the FME Flow Web User Interface. For example: https://fmeflow.example.com/. For more information, see:
