FME Flow: 2025.2
Before Installation
Before you install the FME Flow components for a 3-tier architecture, ensure that:
  • The following non-FME Flow components are in place on your network:
  • The necessary ports are available on your network. Firewalls must permit certain ports to be opened between nodes. For more information, see FME Flow Ports.
  • (Recommended) One or more Windows service accounts have read and write permissions on the network shares of the FME Flow Core/Engines and the Web Application Server. In most distributed installations, this account is necessary for these components to communicate with each other across a network. For more information, see Running the FME Flow System Services Under Different Accounts (Windows).
Next Steps
Proceed to Obtain the Installer.
