FME Flow: 2025.1
Failure to Connect to Azure AD Through IIS Proxy
Symptom
When logging in to FME Flow with credentials from an Azure AD server that you have configured to route through a Microsoft Internet Information Services (IIS) reverse proxy, authentication fails.
Cause
The login HTTP request to the Azure AD server sends a redirect URI of the FME Flow Core hostname rather than the URI of the reverse proxy.
Resolution
- Append the URL of your reverse proxy to the fmeserver.sso.custom.baseurl= line in the SSO application.properties file. If your FME Flow uses an Apache Tomcat web application server provided with the installation, this file is located in <FMEFlowDir>\Utilities\tomcat\webapps\fmesso\WEB-INF\classes\.
- Restart FME Flow.
- Ensure the Redirect URI setting on your Azure Active Directory portal is set to the URL of your reverse proxy (rather than your FME Flow hostname), appended with /fmesso/azuread/redirect.
Tip In your IIS reverse proxy settings, clear Reverse rewrite host in response headers. In IIS Manager, this setting is located in the Application Request Routing Cache tool, under Actions > Server Proxy Settings.
