Geometry Definition
In formats that support reading or controlling the writing of geometric (spatial) data, a Geometry Definition table is visible in the User Attributes tab of a feature type.
This table allows you to
  • Identify when there is geometry data present, including the name of the geometry column (or multiple columns, if multiple geometries are present).
  • Control whether or not geometry data is written and specify geometry type, depending on the format.
Note
  • The Geometry Definition table on a reader feature type is read-only, and not editable, even if Allow Reader Feature Type Editing is checked.
  • In formats that support multiple geometries, the Geometry Definition table is present on the writer only if Schema Definition is Automatic, or if Schema Definition is Manual or Dynamic and Write Geometry Data is Yes . For more information, see User Attributes.
The information contained within the Geometry Definition table includes:
Column Name
Visibility
Description
Name
Always present
The values displayed in this column correspond to what is displayed on the expanded workspace canvas object and in the Schema Preview window:
  • <geometry_column_name> – source feature type's geometry column name, if available. In formats that support multiple geometries, the column name for each geometry that is present is provided.
  • <geometry> for formats that do not support named geometry columns
On writer feature types, you can set Name if Attribute Definition is Manual or Dynamic.
Geometry Type
Always present
Displays the allowed geometry of the feature type for each geometry Name. If the format does not support a specific geometry, <all> displays.
On writer feature types, you can set Geometry Type if Attribute Definition is Manual or Dynamic. To set Geometry Type to the geometry of the first feature that enters the reader, specify <from first feature>.
On writers that support multiple geometries, you can add (+) multiple types as required.
Spatial Type
Optionally shown
If the format's schema feature has information for spatial type, this column displays. Where applicable, this value can be set on the writer feature type.
Resolving Log Warnings
If the translation log displays one of the following warnings, see the related FME Support Center article for tips on resolving the issue.
  • Spatial column '<name>' does not match any of the geometry names in the feature. No spatial data will be written.
  • Spatial column 'GEOM' does not match any of the geometry names in the feature. No spatial data will be written.
Updating Feature Types
When FME detects an update to the feature type, the Feature Type dialog displays an information banner. You can update the dialog to refresh the table content.
