FME Transformers: 2026.2
Categories
Strings
FilenamePartExtractor
Extracts specified parts of a filename path and returns the results as string attributes.
Example
For example, the path
C:\WINNT\Profiles\user\Desktop\roads.shp
would be extracted as follows:
Folder Path
Full Filename
roads.shp
Filename Root
roads
Filename Extension
shp
Folder Name
Desktop
When parsing the path, both backslashes and forward slashes are handled as separators, regardless of operating system.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the FilenamePartExtractor on the FME Community.
