FME Transformers: 2026.2
Categories
3D
3D
Calculated Values
Rasters
Spatial Analysis
DEMDistanceCalculator
Calculates the distance between a number of input vector lines and the elevation values of a reference DEM raster, and outputs a new DEM raster per input line.
The data contained in the resulting DEM consists of the 3D distance between the line being considered and the corresponding point on the reference DEM.
  • This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the DEMDistanceCalculator on the FME Community.
