FME Transformers: 2026.2
3DSlicer
Slices geometry along a specified plane.
- Slicing solids, surfaces, and other 3D geometry with a plane.
The 3DSlicer accepts features with any geometry type and splits them along a specified 3D plane.
Both 3D and 2D geometries are accepted, including points clouds and aggregates. 2D features are handled as 3D with a Z coordinate of zero (0). Aggregates are treated as single objects.
Output features are identified as being on the front or back side of the slicing plane, and are flagged as having been sliced or not. Front and back are relative to the plane, with front being in the direction of the plane's normal vector and back being the inverse. Features that are entirely coincident with the plane are considered to be on the front side.
The slicing plane is defined by:
- Fixed X, Fixed Y, or Fixed Z: Specifying a single axis point in ground units. The normal vector of the plane (determining front and back) is in the positive direction along the fixed axis.
- Point and Normal: Providing a normal vector, composed of:
- Point on Plane - 3D coordinates of a point on the slicing plane.
- Normal Vector of Plane - 3D coordinates of a point representing the normal vector of the slicing plane.
Plane Type |
Orientation |
Fixed X
Fixed Y
Fixed Z
Point and Normal Variable orientation |
Normal Vectors
The normal vector is perpendicular to the slicing plane and indicates its orientation.
For use in this transformer, it is defined in two parts - a point on the plane, and a vector relative to that point. Both parts consist of x, y, z values.
The point on the plane is an absolute position in 3D space, and the vector values are added to those coordinates.
The vector's magnitude (length) is irrelevant for this operation - the vector values can be any distance along the normal vector. The ratio of x:y:z describes the vector's direction.
Determining normal vector values
Normal vectors can be calculated by:
- Subtracting the point on plane from a known fixed coordinate along the normal
- Calculating the normal from three known points on the plane (cross product) - see Finding the normal to a plane
- Take the coefficients from the plane's scalar equation, in the form Ax + By + Cz = D.
Once a normal has been calculated, it can be applied to any point on the plane.
- Only 3D plane geometry may be used to slice.
Features with valid geometry to be sliced.
Features sliced as specified in parameters. Unsliced features are output with geometry unchanged.
Features with invalid or otherwise non-sliceable geometry are output here, as are any features that receive non-numeric values for any numeric parameters.
INVALID_PARAMETER_PLANE_SPECIFICATION
INVALID_GEOMETRY_VERTICES
INVALID_GEOMETRY_NOT_FINITE
INVALID_GEOMETRY_NONSPATIAL
INVALID_GEOMETRY
INVALID_GEOMETRY_UNPROCESSABLE_CURVE
INVALID_GEOMETRY_UNPROCESSABLE_AREA
INVALID_GEOMETRY_UNPROCESSABLE_SURFACE
INVALID_GEOMETRY_UNPROCESSABLE_SOLID
Plane Type |
Select a plane definition mode:
Fixed Value |
When Plane Type is Fixed X, Fixed Y, or Fixed Z, specify the plane position along the selected axis in ground units. |
Custom Plane |
When Plane Type is Point and Normal, specify the following coordinates:
Plane Side Indicator |
Name the attribute to contain the sidedness of the output geometry relative to the slicing plane. Possible values are:
Sliced Indicator |
Name the attribute to contain the slicing status of output geometry. Possible values are:
Search for all results about the 3DSlicer on the FME Community.
