Esri Knowledge Graph Reader Parameters
Database Connection
Select an existing Esri Knowledge Graph connection, or Add Database Connection...
Add Esri Knowledge Server Connection
To define a new connection from the Connection parameter, see the topic Esri Knowledge: Add Connection.
Constraints
Note  If the Esri ArcGIS Compatibility workspace parameter is set to Auto, and both Esri ArcMap and Esri ArcGIS Pro are installed on the system, browsing tables may not behave as expected. To fix, uninstall Esri ArcMap, or set Esri ArcGIS Compatibility to Esri ArcMap or Esri ArcGIS Pro. For more information, see Workspace Parameters.
Schema Attributes
Spatial
Search Envelope
Advanced
