FME Form: 2026.2 BETA
Workspace Parameters
Note  Similar parameters exist for custom formats and custom transformers. The title of the parameter changes depending on what is open on the canvas. For example, when a custom transformer is open, you will see Transformer Parameters instead of Workspace Parameters.
AI Assist
Enable context in the AI chat
If Yes, AI Assist queries apply to selected items in the workspace. If No, AI assist queries apply to the entire workspace. The default value of this parameter is obtained from the Enable context in the AI chat setting in FME Options.
General
Name
Update the default name, if desired. We suggest a more descriptive title (for example: CAD-GIS: Converting text to attributes).
The name is displayed on the title bar of the FME Workbench window.
To rename a template, open it, then select File > Save As Template with the new name.
Password
You can password-protect workspaces, custom formats and custom transformers.
Double-click the Password parameter . In the Password dialog, enter a case-sensitive password at least 12 characters in length. Each time you try to open the workspace, you will be prompted for the password. If you save the workspace under a different name, the password protection will also be duplicated.
Note   When you create a password-protected file, make sure you use a password that you can easily remember. If you lose the password, you cannot open or gain access to the file.
Category
Specify a category. You can use categories to organize or group related items when you upload to FME Hub. If a category contains transformers, the category name appears in the Transformer Gallery.
Overview
Enter a description. The description is particularly important when you are using the workspace from FME Flow because it provides a mechanism for a web page to describe what the process is intended to carry out.
The description you enter appears in the Description parameter with the proper encodings for spaces, formatting, etc.
Help
List any special instructions here. Example:
You can also use this area to:
  • List any requirements that must be met before using the workspace or template, such as where the source data resides or minimum FME version required. You should also list any dependencies (for example, if you need a third-party application or an extra-cost transformer).
  • Record any legal information (for example, copyrights or data restrictions).
Use Markdown
When checked, some rich text features of the dialog are not available. This box must be checked if you want to upload to FME Hub.
History
Record changes made to the workspace. This is especially good practice if you are sharing data or workspaces.
Example:
Last Save Date, Last Save Build
The History tab also displays the date and FME build on which the workspace was last saved.
Prompt and Preview
Prompt And Run
Specifies the default behavior of the Save As User Parameter Default Values setting when Running a Workspace with User Parameters. If Save Parameter Values is Yes, this setting is checked by default. If No, this setting is not checked by default.
Prompt for Parameters
If Yes, the workspace pauses translations to display a dialog that prompt for user parameter values. For more information, see Running a Workspace with User Parameters.
Enable Feature Counting
If Yes, the workspace displays feature counts when run.
Enable Data Caching
If Yes, the workspace runs with Data Caching enabled.
Stop at Breakpoints
If Yes, the workspace stops at each breakpoint when run.
Incomplete Cache Handling
If Enable Data Caching is Yes, instructs FME on how to treat data caches that are in an incomplete state.
  • Treat as Stale: When the workspace re-runs, caches regenerate if required for downstream translation.
  • Treat as Up-to-date: When the workspace re-runs, caches are considered up-to-date and are not regenerated.
Order and Redirect
Reader/Writer Redirect
You can quickly reroute your output without having to add anything to your workspace. You might want to do this if you're having problems in your workspace, and want to examine features or information before writing to your original output file or folder.
To redirect, double-click Reader Redirect or Writer Redirect:
  • No Redirect: This is the same as keeping the <not set> default.
  • Redirect to Inspection Application: View data in the default inspection application before writing to the output file or folder.
  • Redirect to FFS File: This option is useful for debugging complex workspaces. The output is written to FME Feature Store files (FFS). The FFS files can then be viewed using the FME Data Inspector. Redirect to FFS can also be used to send database data to Safe Support. Since this option does not use the format writers configured in the workspace, it can be used to isolate problems that may be occurring in a specific FME format writer.
  • Redirect from FFS file: Used for debugging complex workspaces. Output that has been created using Redirect to FFS file can be reloaded into the workspace using Redirect from FFS file.
  • Disable Output: Instead of writing many features to a dataset, you might just want to see information or statistics gathered during processing. No features will be output.
After you run the workspace, the log displays a message as a reminder that you have redirected your source or destination.
Note  For detailed information on the FFS format, see the FME Feature Store (FFS) Reader/Writer chapter in the FME Readers and Writers manual. For help with the FME Data Inspector, open the Help menu in the FME Data Inspector application.
Terminator Redirect
The Terminator transformer is used to detect non-valid situations. When a feature is directed to this transformer, the translation immediately stops and displays an error message (by default, Translation Terminated). If you are programming or debugging, you would usually disable the connections to the Terminator and then add an Inspector to verify if the features are real errors. In production mode, you then have to re-enable these connections and delete the Inspector.
This option allows you to automatically redirect the features that enter the Terminator to an Inspector, without having to modify the workspace. When this option is activated, all the features that enter a Terminator are redirected to an Inspector and the translation continues without stopping. A message is added to the log file to indicate that some features were redirected to an Inspector.
Order Writers By
See Order Writers By.
Log and Troubleshoot
Log File
  • Log File: The filename and path for the translation log. The filename defaults to the WORKSPACE_NAME FME parameter. This setting overrides the Save Log to File setting under FME Options > Translation. This field allows constructing filenames with parameters and functions.
  • Include Datetime: If checked, the timestamp of the log is appended to the log filename as the FME_RUN_TIMESTAMP FME parameter. This option may be useful to distinguish log files of workspaces that are run multiple times.
Max Features to Log
See Max Features to Log.
Max Logged Features to Record
See Max Logged Features to Record.
Ignore Failed Readers
See Ignore Failed Readers.
Rejected Feature Handling
Specifies the behavior of the workspace if it contains transformers with <Rejected> output ports, and a translation outputs a feature to one of these ports.
  • Terminate Translation: The translation terminates when the first feature is output to a <Rejected> port that does not connect to another input port.
  • Continue Translation: The translation continues to run regardless of any features output to a <Rejected> port.
An alternative way to set this parameter is to right-click on any <Rejected> port, and select Workspace: Rejected Feature Handling. If you set the parameter this way, the setting still applies to all <Rejected> ports in the workspace in the same way as setting it from the Navigator window.
Note  To set the default behavior of this parameter for all newly-created workspaces, select Utilities > FME Options > Workspace Defaults.
Enable Performance Profiling
If Yes, the workspace provides a performance report after it runs. For more information, see Monitoring Workspace Performance.
Spatial
Reprojection Engine
See Reprojection Engine.
Esri ArcGIS Compatibility
Specifies the requirements for a workspace equipped with any format that requires an Esri ArcGIS license.
Note  To control the default setting of this parameter for new workspaces, select Utilities > FME Options, open the Workspace Defaults pane, and set the ESRI ArcGIS Compatibility translation parameter.
  • Auto: If required, Esri ArcMap, Esri ArcGIS Pro, or equivalent must be installed and licensed on the system.
  • Esri ArcGIS Server/ArcGIS Pro: Esri ArcGIS Pro or equivalent must be installed and licensed on the system.
  • Esri ArcGIS Server Legacy (ArcMap Compatible): Esri ArcMap or equivalent must be installed and licensed on the system.
Stroking Tolerance
See Stroking Tolerance.
Scripting
Python Compatibility
See Python Compatibility.
Startup Python Script, Shutdown Python Script
See Startup and Shutdown Python Scripts.
Run Python Startup/Shutdown Scripts
If Yes, any Startup and Shutdown Python Scripts of the workspaces, are enabled. If No, they are disabled and do not run with workspaces. Disabling these scripts may be useful while troubleshooting a workspace.
Workspace Header
See Workspace Header
Advanced
Note  The following parameters appear when you open a custom format.
Multiple Dataset Processing
Controls whether multiple datasets of a custom format are treated as a single set of features, or as separate sets of features. If Single Group is specified, features in all datasets are read and processed in the workspace as a single group. If Group By Dataset is specified, features are processed and grouped separately by dataset, similar to a GROUP BY clause in a database query. For example, if the custom format contains an Intersector transformer, features are only intersected against others in the same dataset.
Note  In order for the Group By Dataset setting to process features accurately, format attributes fme_basename and fme_dataset must be explicitly exposed in all reader feature types.
Associate Custom Format with File Filter
If Yes is specified, only files of the type that form the basis of a custom format are browsed. For example, if a CSV file is the basis for a custom format, then only CSV files are browsed by default.
Inherit Spatial Enabling from Primary Reader
If Yes, readers are spatially enabled if a custom format's primary reader is spatially enabled. Spatial enabling, available in certain readers, allows optimized accessing of data in FME Objects applications, or when a bounding box is supplied when reading data.
Source Provides Schema Features
It is possible to create a custom format from a reader as a resource, which does not provide actual feature types. If the custom format provides features in the appropriate form for a dynamic writer, set this parameter to Yes. If No, the custom format is not treated as a dynamic workspace, and the features it provides are treated as actual feature types.
