FME Form: 2026.2 BETA
Transformer Parameter Menu Options
Most transformer parameters are now integrated so that the options can be easily configured with other elements in the workspace.
This means that the parameters can be set, changed, made visible or hidden, set to an attribute value, or linked to another parameter. More advanced functions, such as an advanced editor and an arithmetic editor, are also available in some transformers.
Note  It's important to remember that you can still use a transformer with its default values, as long as there are no required parameters (red-shaded fields). The parameter menu allows easy access more advanced settings.
Accessing the Parameter Menu
The options that will appear for a transformer depend on the type of transformer that you are using. If the transformer supports it, the menu displays after you open the transformer properties and click the parameter menu button on the right side. This menu will usually display different options for each transformer parameter. The most common parameters are described below.
Common Menu Options
These menu choices are available in most transformers:
Menu Choice Available Description
User Parameter
For all parameters except transformer name and new attribute names
This will set the value of the parameter to a user, system, FME Flow, or FME deployment parameter.
There are three ways you can set to a parameter:
Clear Value
Always
Clears all values and returns the parameter to an empty state.
For choice parameters, Clear Value will take you back to the drop-down list.
Attribute Value
If the parameter can take the value of an existing attribute from the input feature
Set a parameter value to the value of an existing attribute.
Even if the parameter takes only a simple Yes/No value, you might want to ensure that you carry this value through to other transformer parameters without having to explicitly set them.
Cached Values If the workspace was run with data caching, and cached values are present. Sets a parameter value to a cached value.
Add Annotation
Parameters in any top-level transformer parameter dialog (does not include parameters in sub-dialogs)
Allows you to annotate a parameter setting. Annotations can provide useful information about the reasons for parameter settings.
Edit Annotation
Parameters with existing annotations
Opens the Annotation Editor for updating an existing parameter annotation.
Delete Annotation
Removes a parameter annotation.
Other Menu Options
Some parameter menu choices that appear depend on the transformer parameter type. Because each transformer parameter is unique, the associated parameter menu is also unique.
The table below lists some of the more common transformer-specific options:
Menu Choice Description
Change Selection
Opens a dialog that allows you to choose multiple list items. For example, all transformer Group By parameters display this menu choice.
Select Attribute
Select an attribute from the list.
Choose Font
In transformers that include font definitions, this menu choice displays the font chooser dialog.
Open Arithmetic Editor
Opens a dialog that allows you to input an arithmetic equation, such as “1+2”, that will be evaluated at runtime.
Open Text Editor
Opens the text editor.
Edit Selection
Opens a dialog to select resources that are generally accessed remotely, such as from a web connection.
Open Advanced Selection Editor
Opens the Advanced Selection Editor.
Open Regex Editor
Opens a Regular Expression Editor.
Select Color
For any parameters that accept color definitions, this menu choice opens a color picker specific to the operating system.
Select Coordinate System
For any parameters that accept coordinate system definitions, this menu choice opens the Coordinate System Gallery.
Select Folder/Source Filename/Dataset File/Image/FME Workspace
Opens a folder/file browser in transformer parameters that require folders or files as input.
Select Format
Allows you to select the format of a reader or writer.
Select Raster
Opens a dialog that allows you to select raster bands and palettes.
Select XML.
When selected in transformers that work with XML files, provides the option of opening a file browser or specifying an attribute.
Set Geometry
Opens a dialog that allows you to define geometry.
Function Return
Parameter is set to the value returned by a function.
Conditional Value
Opens the Parameter Condition Definition dialog.
Stop Translation
If the value cannot be set automatically, the translation is stopped.
No Action
The value of the attribute is left ‘as is’ without being modified.
Null
The parameter is assigned a value of null.
