FME Flow: 2026.2
Creating an Authentication Service Connection
Warning  When configuring authentication services, do not remove or disable the FME Flow system user admin or any other user assigned to the fmesuperuser system role. These accounts are required to maintain access to the Web User Interface in the case of connection loss to the identity provider.
What's Next?
Proceed to Adding Users and Roles from an Authentication Services Connection.
