FME Flow: 2026.2
Before Installation
Before you install the FME Flow components for a 2-tier system, ensure that:
  • The following non-FME Flow components are in place on your network:
  • The necessary ports are available on your network. Firewalls must permit certain ports to be opened between nodes. For more information, see FME Flow Ports.
Next Steps
Proceed to Obtain the Installer.
