FME Transformers: 2026.1
Categories
Geometries
Related Transformers
Bufferer
Offsetter
OffsetCurveGenerator
Creates offset parallel lines on either side of curve features.
Jump to Configuration
  • Creating parallel lines to the left, right, or both sides of a curve feature
The OffsetCurveGenerator takes in curve features and creates new curves on either side of the original. These new lines are placed at a specified Offset distance from the original, on the left and right-hand sides. There is a choice of how corners are created - round, mitered, or beveled.
The new offset curves are output as Right and Left, according to the orientation of the original feature.
Two options for Buffer Mode are available. Standard (Fast) can generalize the geometry, producing faster and simpler results. Precise honors the input.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies
Aliases BufferCurveGenerator
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the OffsetCurveGenerator on the FME Community.
