FME Transformers: 2026.1
Categories
Geometries
Related Transformers
ArcStroker
Chopper
Generalizer
RasterResampler
Densifier
Adds vertices to linear features at regular intervals.
Jump to Configuration
  • Preserving geometry shapes through reprojection
  • Adding vertices for more even feature chopping
The Densifier receives features with line or area geometry and adds additional vertices to them at regular intervals.
Spacing is specified in ground units, and the placement is guided by Mode:
  • Exact Interval: Vertices are added at the specified interval after each existing vertex.
  • Uniform Interval: Each segment of the feature is considered individually. The segment receives new vertices dividing it into equal parts. The number of parts is guided by the Interval value, and the distance between vertices can vary between segments.
Settings
Result
Input Feature
Exact Interval
Uniform Interval
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the Densifier on the FME Community.
