Industry Foundation Classes (IFC) Geometry Support
See Also
- Industry Foundation Classes (IFC) Quick Facts
- IFC-to-FME Geometry Mapping
- FME Geometry Model
- FME-Supported Geometries
Geometry |
Supported? |
Notes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Solids that cannot be represented natively as solids by FME will be read as composite surfaces instead. |
Coordinate Precision |
Yes |
Yes |
Swept area solids with openings are read as CSG solids if the Subtract Opening Geometry parameter is enabled. Ifc CSGs are supported for reading, but not writing. CSGs that do not represent a solid and its openings will be written out as an IfcFacetedBrep element. |
Yes |
Yes |
Yes |
Yes |
Yes |
IfcMappedItem elements are read as geometry instances; conversely, geometry instances are written out as IfcMappedItem elements. |
Georeferencing |
Native |
Yes |
Yes |
Yes |
Yes |
Yes |
Meshes will be written out as IfcFacetedBrep elements. |
Yes |
Yes |
Multiple Geometries |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Surface Sidedness |
Yes |
Partially |
IfcSurfaceStyleWithTextures attributes can be round-tripped through FME; however, the textures themselves cannot be viewed in the FME Data Inspector. |
Yes |
Yes |
Z values |
Yes |
