IFC-to-FME Geometry Mapping
Quick Links
Solids and Surfaces
Note
  • IFC solid geometries not explicitly listed in the Solids and Surfaces flow chart are represented in FME as Composite Surfaces, and are written out as IfcFacetedBrep elements.
  • IfcTesselatedFaceSet elements are represented in FME as BRep Solids to preserve holes in the geometry.
Curves
Points, Text, and Geometry Instances
Note  Any IfcShapeRepresentation with multiple representation items will be represented in FME as an Aggregate.
