FME Transformers: 2025.2
Categories
Cartography and Reports
Geometries
Related Transformers
Generalizer
SherbendGeneralizer
Simplifies geometry while preserving spatial relationships and applying spatial constraints.
Jump to Configuration
  • Preparing geometry for different scales
  • Generalizing while preserving spatial relationships between features
The SherbendGeneralizer receives features with vector geometry and applies the Sherbend generalizing algorithm to them. Incorporating the Wang-Müller algorithm with added spatial constraints, it removes and adjusts vertices to simplify features without losing the spatial relationships between feature geometries.
Bends are iteratively evaluated against a reference circle of a specified Diameter. For each bend, a value is calculated - 75% of the area of a circle with circumference equal to the bend’s perimeter. If this value is less than the area of the reference circle and any selected spatial constraints are met, the bend is generalized. Any conflicts are resolved, and the process is repeated until no further generalization is possible.
The larger the Diameter, the more likely it is that bends will be generalized.
Where lines are closed, the endpoints may be either kept stationary (preserving juncture connectivity if necessary) or considered for generalization.
Spatial Constraints
Spatial constraints can be applied or not. When they are applied, conflicts with the constraint are output separately via the Conflicts output port. Note the conflicting geometry reflects the final generalized output.
Self Intersection
Self Intersection prevents a line from intersecting with itself, with the assumption that input lines do not self-intersect.
Input
Generalized without constraint
Conflict
Generalized with constraint
Line-Line Intersection
Line-Line Intersection prevents a line from intersecting another line, with the assumption that input lines do not intersect each other.
Input
Conflict
Sidedness
Sidedness maintains the relative positioning of all lines and points.
Input
Conflict
  • Results may be improved by using TopologyBuilder, GeometryValidator, or Intersector transformers prior to the SherbendGeneralizer.
  • To generalize individual features with no constraints, use the Generalizer.
  • The Generalizer’s generalizing algorithms may be useful before or after the SherbendGeneralizer to further reduce vertex density.
  • The SherbendGeneralizer does not accept area geometry. A GeometryCoercer or TopologyBuilder may be useful for pre-processing features.
  • Constraint checking is a highly time-intensive operation. Use constraints only as necessary.
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the SherbendGeneralizer on the FME Community.
