FME Transformers: 2025.2
Categories
Calculated Values
Related Transformers
PointPropertySetter
PointPropertyExtractor
Extracts point orientation to feature attributes.
Note  Feature order may change in relation to other output ports. Feature order per port is maintained.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the PointPropertyExtractor on the FME Community.
