FME Transformers: 2025.2
ParameterFetcher
Adds an attribute to the feature, supplying it the value of a previously defined parameter.
A parameter is a setting that you can pass values into when a translation is run. Parameters usually relate to a setting on a reader or transformer. The ParameterFetcher can be used to copy the value of one or more parameters to a corresponding number of attributes. The number of rows specified in the configuration dialog determine the number of exposed output attributes.
Parameter Name |
When the ParameterFetcher is connected, the Parameter Name drop-down list shows the parameters that can be fetched from the workspace. The Parameter Name also exposes FME Parameters and FME Flow Parameters. |
Target Attribute |
The target attribute is the name of the attribute that will be created. When you select a parameter, this field is automatically filled with an appropriate name (for example, selecting a parameter named WIDTH will automatically name the target attribute _WIDTH). You can use the default name, or type a new name. |
Search for all results about the ParameterFetcher on the FME Community.
