FME Transformers: 2025.2
Categories
Geometries
MultipleGeometryCoercer
Splits an aggregate into multiple geometry columns, with one column for each part of the original aggregate.
For example, if a feature enters and it contains an aggregate with two parts, a line and a polygon, the feature will leave containing the same two parts, but each will now be stored as its own separate geometry. A database writer that supports multiple geometry columns may then write out each of the geometries to a separate column.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases IndividualGeometriesSetter MultipleGeometrySetter
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the MultipleGeometryCoercer on the FME Community.
