FME Transformers: 2025.2 BETA
Categories
Integrations
Web
Web
Workflows
Related Transformers
GoogleDriveConnector
S3Connector
SharePointOnlineConnector
AutodeskDocsConnector
Connects to Autodesk Docs, Autodesk Construction Cloud or Autodesk Build to manage files and folders.
Jump to Configuration
  • Manage files on Autodesk Docs by uploading, downloading, and deleting files and folders.
  • Transfer a file's contents into or out of an attribute in FME.
  • Retrieve file and folder names, paths, and other information from Autodesk Docs to use elsewhere in a workspace.
The AutodeskDocsConnector uses your Autodesk account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the file storage service.
Depending on your choice of actions, it will upload or download files, folders, and attributes; list information from the service; or delete items from the service. On Upload and List actions, links and file/folder information are added to the output features as attributes.
Authentication
The AutodeskDocsConnector uses an oauth web service defined FME web connection. It is recommended to create a new web connection using the Autodesk Docs (safe.autodesk-docs) web service. It is also recommended to replace the included FME Forge app client with your own Forge application by updating the client id and secret in Autodesk Docs (safe.autodesk-docs). At minimum, the Forge app must have access to the Data Management API.
It is also required to add FME to your Autodesk Construction Cloud or Autodesk Build account via the Autodesk App Store.
See also: Adding FME through the Autodesk App Store for Use in the AutodeskDocsConnector
  • This transformer cannot be used to directly move or copy files between different Autodesk Docs locations. However, multiple AutodeskDocsConnectors can be used to accomplish this, by downloading files/folders and re-uploading them to a new location.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies Autodesk Docs, Autodesk Construction Cloud (ACC), or Autodesk Build Account, recommended to have a Forge App with access to the Data Management API
Aliases AutodeskBIM360DocsConnector AutodeskConstructionCloudConnector
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the AutodeskDocsConnector on the FME Community.
