FME Transformers: 2025.2
Categories
3D
3D
Coordinates
Geometries
Related Transformers
2DForcer
Extruder
PointOnRasterValueExtractor
SurfaceDraper
3DForcer
Adds z coordinates to features, creating or modifying 3D geometry.
Jump to Configuration
  • Converting 2D geometry to 3D
  • Updating z coordinates with new values
The 3DForcer receives any geometry type and adds z coordinate values, converting 2D features to 3D.
Z values may be supplied by an attribute, expression, or user parameter. Existing z values may be preserved or overwritten. If a non-numeric value is provided, features will output via the <Rejected> port.
Z values should generally be in the same units as the x and y coordinates. Features with latitude/longitude coordinate systems may need to be reprojected.
Raster features, including digital elevation models, will pass through unchanged.
  • This transformer applies the same z value to all vertices of a feature. To interpolate vertex elevation values from another dataset, use the SurfaceDraper.
  • To apply elevations from an underlying digital elevation model, use the PointOnRasterValueExtractor.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases ElevationSetter
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the 3DForcer on the FME Community.
