Industry Foundation Classes (IFC) Reader Parameters
- Read Property and Quantity Set Definitions – Check this option to enable reading PropertySetDefinition features. Property and quantity sets will have an ifc_element_type of PropertySet and ElementQuantity respectively. User-defined sets will have suffixed type attributes for each property or quantity in the set, including .PropertyType and .ValueType.
- Read Material Definitions – Check this option to enable reading MaterialDefinition features. MaterialDefinition features can have an ifc_element_type of Material, MaterialList, or MaterialLayerSet.
Schema Attributes
Use this parameter to expose Format Attributes in FME Workbench when you create a workspace:
- In a non-dynamic scenario, this parameter allows you to expose additional attributes on multiple feature types. Click the browse button to view the available format attributes (which are different for each format) for the reader.
Spatial
Coordinate systems may be extracted from input feature data sources, may come predefined with FME, or may be user-defined. FME allows different output and input coordinate systems, and performs the required coordinate conversions when necessary.
If a coordinate system is specified in both the source format and the workspace, the coordinate system in the workspace is used. The coordinate system specified in the source format is not used, and a warning is logged. If a source coordinate system is not specified in the workspace and the format or system does not store coordinate system information, then the coordinate system is not set for the features that are read.
If a destination coordinate system is set and the feature has been tagged with a coordinate system, then a coordinate system conversion is performed to put the feature into the destination system. This happens right before the feature enters into the writer.
If the destination coordinate system was not set, then the features are written out in their original coordinate system.
If a destination coordinate system is set, but the source coordinate system was not specified in the workspace or stored in the source format, then no conversion is performed. The features are simply tagged with the output system name before being written to the output dataset.
For systems that know their coordinate system, the Coordinate System field will display Read from Source and FME will read the coordinate system from the source dataset. For most other input sources, the field will display Unknown (which simply means that FME will use default values). In most cases, the default value is all you'll need to perform the translation.
You can always choose to override the defaults and choose a new coordinate system. Select More Coordinate Systems from the drop-down menu to open the Coordinate System Gallery.
Changing a Reprojection
To perform a reprojection, FME typically uses the CS-MAP reprojection engine, which includes definitions for thousands of coordinate systems, with a large variety of projections, datums, ellipsoids, and units. However, GIS applications have slightly different algorithms for reprojecting data between different coordinate systems. To ensure that the data FME writes matches exactly to your existing data, you can use the reprojection engine from a different application.
To change the reprojection engine, Select Workspace Parameters > Spatial > Reprojection Engine. In the example shown, you can select Esri (but the selection here depends on your installed applications):
- The coordinate systems file coordsys.db in the FME installation folder contains the names and descriptions of all predefined coordinate systems.
- Some users may wish to use coordinate systems that do not ship with FME, and in those cases, FME also supports custom coordinate systems.
- Learn more about Working with Coordinate Systems in FME.
Use this parameter to enable or disable reading all of the geometric representations found in the source file.
Use this parameter to select which geometric representations in the file should be read.
If no representations are selected, Body and Axis representations will be read by default.
Unnamed representations will be given a default name of Unnamed_<ifc_representation_type>, or Unnamed if the representation type is also empty.
Use this parameter to select whether the IFC_API reader reads Georeferenced or Local coordinates on features.
- Georeferenced coordinates will have the transformation specified by the IfcCoordinateOperation (either IfcMapConversion or IfcRigidOperation) applied, and the associated IfcCoordinateReferenceSystem (either IfcProjectedCRS or IfcGeographicCRS) will be set as the coordinate system on the feature.
- Local coordinates will not have the IfcCoordinateOperation (either IfcMapConversion or IfcRigidOperation) applied, and the feature will not be tagged with a coordinate system.
A search envelope (also known as a bounding box) is a rectangular area that defines a geographic area. In FME, the easiest way to define a search envelope is to use search envelope parameters.
Defining a search envelope is the most efficient method of selecting an area of interest because FME will read only the data that is necessary – it does not have to read an entire dataset. Search Envelope parameters apply to both vector and raster datasets and can be particularly efficient if the source format has a spatial index.
Most FME readers have parameters to define the search envelope of data that is being read:
The parameters include the x and y coordinates of the bounding box as well as a parameter that defines the coordinate system.
How to Define the Bounding Box
Using the minimum and maximum x and y parameters, define a bounding box that will be used to filter the input features. Only features that intersect with the bounding box are returned. Note that the bounding box intersection is not a full geometry intersection (based on spatial relationships) that would be returned by a transformer like the SpatialFilter.
Search Envelope Coordinate System |
Specifies the coordinate system of the search envelope if it is different than the coordinate system of the data. The coordinate system associated with the data to be read must always be set if this parameter is set. If this parameter is set, the minimum and maximum points of the search envelope are reprojected from the Search Envelope Coordinate System to the reader’s coordinate system prior to applying the envelope. |
Clip to Search Envelope |
The underlying function for Use Search Envelope is an intersection; however, when Clip to Search Envelope is checked, a clipping operation is also performed.
Advanced
When selected, the IFC model will be validated against its schema version after the input file is read. Any schema violations will be output as errors in the translation log.
This setting controls how nested attribute names are separated when reading IFC data, including property sets, quantity sets, and other nested structures. By default, the delimiter is ".", so attributes appear as Pset_WallCommon.Reference. Any single character except a space can be used as the delimiter. If the dataset contains the chosen delimiter in set or property/quantity names, the reader will output a warning, and the IFC writer will not output these attributes correctly.
Note that list attributes will be delimited by "." in all cases, regardless of the selected delimiter (for example, ifc_is_defined_by{}.Name)
When checked (default), openings will be read and a void will be calculated and removed from the geometry. Solids will be turned into CSGs.
- Output Opening Geometry in Subtractions – When checked, opening geometry will be drawn. All opening geometry is transparent, and is appended as an aggregate part to a feature’s existing geometry.
