FME Flow: 2025.2 BETA
Changing the Database Provider for the FME Flow Database
Warning
Due to dependencies in the FME Flow environment, the procedure described here is not recommended for Express installations. Instead, we recommend the following procedure to change the database provider:
  1. Back up the current configuration of FME Flow.
  2. Uninstall FME Flow and re-install a 2-tier Distributed architecture, specifying the new database provider.
  3. Restore the FME Flow Configuration.
To change the database provider for the FME Flow Database, perform an “in-place” backup and restore procedure:
  1. Download Your Custom Encryption Key
  2. Backup Your FME Flow Configuration
  3. Configure the New Database Server
  4. Configure the Database Connection
  5. Restart FME Flow
  6. Restore Your FME Flow Configuration
  7. Remove Dependency, Disable, and Stop the Previous Database Service
FME Flow supports PostgreSQL (recommended), SQL Server, or Oracle databases.
Note  PostgreSQL is the recommended database server with FME Flow, offering enhanced performance and stability through targeted optimizations.
If System Encryption is Standard (the default setting), changing the databases provider generates a new system encryption key on restart. If you have not already done so, ensure your current custom encryption key is downloaded and safely saved, in case you need to reuse it.
Perform a backup of your FME Flow configuration.
Run the necessary database configuration scripts and post-configuration scripts. Follow the steps in Configure the FME Flow Database on a Separate Database Server.
Note
If using an Oracle database server, you must obtain the Oracle Database JDBC driver and place it in the following directory:
  • Windows:
    • <FME FlowDir>\FMEFlow\Utilities\jdbc
  • Linux:
    • /opt/fmeflow/Utilities/jdbc
Driver versions recommended: 12.1 (ojdbc7.jar), 12.2 (ojdbc8.jar), 18.3 (ojdbc8.jar), 19.3 (ojdbc8.jar), 19.3, 19.6, 19.7 (ojdbc8.jar).
Driver versions not recommended: All ojdbc10.jar versions.
For more information, see https://www.oracle.com/technetwork/database/application-development/jdbc/downloads/index.html.
  1. Encrypt the database password you generated in the previous step. In an initial installation of FME Flow, this password is encrypted in installation files by default. However, it is no longer encrypted when the database server is updated. Follow the procedure in Encrypting the FME Flow Database Password.
  2. Locate the fmeDatabaseConfig.txt configuration file.
  3. Under the heading ‘FME SERVER SETTINGS START’, locate the section titled 'Database Connection' and update the parameters for the database you want to use for your repository.
  4. Parameters
    DB_TYPE - Identifies the database server: postgresql, sqlserver, oracle.
    DB_DRIVER - The JDBC driver name used for connecting to the database.
    DB_JDBC_URL - The JDBC URL used for connecting to the database.
    DB_USERNAME - The database user name.
    DB_PASSWORD - The database user password.
    DB_CONNECT_EXPIRY - The database connection expiry time, in seconds.
    DB_SQLSTMTS_PATH - The path to the SQL statement resource bundle.
Restart FME Flow
Restart all of the FME Flow System Services.
Note  Upon restart, FME Flow generates a new System Encryption key. We recommend downloading this key for safekeeping.
Perform a restore of your FME Flow configuration.
If the database service from which you migrated is the PostgreSQL database that was included in a default installation of FME Flow (such as an express install), you must remove the dependency of the FME Flow Core on that database, and then disable and stop it. For more information, see Removing the FME Flow Core Dependency on the FME Flow Database.
