FME Transformers: 2025.1
Categories
Integrations
Web
Web
Workflows
TrimbleConnectConnector
Connects to Trimble Connect to manage files and folders.
Jump to Configuration
  • Managing files on Trimble Connect by uploading, downloading, and deleting files and folders
  • Transferring file contents into or out of an attribute in FME
  • Retrieving file and folder names, paths, and other information from Trimble Connect to use elsewhere in a workspace
The TrimbleConnectConnector uses your Trimble Connect account credentials to perform various management tasks:
Action Task
Delete
Delete files and folders.
Download
Download a file or folder to an attribute, file, or folder.
List
List the item details for the contents of a folder.
Upload
Upload a file, folder, or the contents of an attribute.
Once valid account credentials have been provided, you may browse to available content for the selected Action.
Trimble Connect Limitations
  • Folder and file names have a 255 character limit.
  • Upload size limit for a single file is 5 GB.
  • Files larger than 5 MiB will be uploaded via multipart upload, with a chunk size of 250 MB.
  • As described in the Trimble Connect API documentation, the upload will be marked as “EXPIRED” (and the feature rejected) if the file is not uploaded within 90 minutes for single-part upload.
Optional Input Port
This transformer has two modes, depending on whether a connector is attached to the Input port or not:
  • Input-driven: When input features are connected, the transformer runs once for each feature it receives in the Input port.
  • Run Once: When no input features are connected, the transformer runs one time.
When the Input port is in use, the Initiator output port is also enabled.
  • This transformer cannot move or copy files between different locations. Consider using multiple connectors for these tasks, by downloading files/folders and re-uploading them to a new location.
  • The FeatureReader can access Trimble Connect directly but does not download a local copy of the dataset.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies Trimble Connect account
Aliases TrimbleConnector
History Released FME 2023
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the TrimbleConnectConnector on the FME Community.
