FME Transformers: 2025.1 BETA
Categories
Strings
Related Transformers
StringReplacer
StringSearcher
Performs a regular expression match on the specified expression.
If the expression matches the pattern, the feature is output via the Matched port, and the portion of the original search string that matched the regular expression is stored in the attribute specified in the Matched Result Attribute (and optionally matching pieces of the expression are stored in the attribute list specified in the All Matches List Name and Subexpression Matches List Name parameters, along with the starting indices of each piece). Otherwise, it is output via the NotMatched port.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases Grepper
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the StringSearcher on the FME Community.
