FME Transformers: 2025.1 BETA
Categories
Strings
Related Transformers
StringPairReplacer
StringSearcher
StringReplacer
Replaces substrings matching a string or regular expression in the string contained in the source attribute.
In this example, a pure substitution of text is made without any use of regular expression functionality. This is the simplest kind of substring replacement.
   Source String: Bobby
   Text to Find: obb
   Replacement Text: ill
   Use Regular Expression: no
   Case Sensitive: yes
   Result: Billy
In this example, a pattern matching zero or more ’b’ characters is replaced with nothing.
   Text to Find: b*
   Replacement Text:
   Use Regular Expression: yes
   Case Sensitive: yes
   Result: Boy
In this example, a pattern matching zero or more ’b’ characters followed by a y is duplicated in the result (prepended by hyphens)
   Text to Find: (b*y)
   Replacement Text: --\1-\1
   Case Sensitive: yes
   Result: Bo--bby-bby
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the StringReplacer on the FME Community.
