FME Transformers: 2025.1 BETA
SherbendGeneralizer
Simplifies geometry while preserving spatial relationships and applying spatial constraints.
- Preparing geometry for different scales
- Generalizing while preserving spatial relationships between features
The SherbendGeneralizer receives features with vector geometry and applies the Sherbend generalizing algorithm to them. Incorporating the Wang-Müller algorithm with added spatial constraints, it removes and adjusts vertices to simplify features without losing the spatial relationships between feature geometries.
Bends are iteratively evaluated against a reference circle of a specified Diameter. For each bend, a value is calculated - 75% of the area of a circle with circumference equal to the bend’s perimeter. If this value is less than the area of the reference circle and any selected spatial constraints are met, the bend is generalized. Any conflicts are resolved, and the process is repeated until no further generalization is possible.
The larger the Diameter, the more likely it is that bends will be generalized.
Where lines are closed, the endpoints may be either kept stationary (preserving juncture connectivity if necessary) or considered for generalization.
Spatial Constraints
Spatial constraints can be applied or not. When they are applied, conflicts with the constraint are output separately via the Conflicts output port. Note the conflicting geometry reflects the final generalized output.
Self Intersection
Self Intersection prevents a line from intersecting with itself, with the assumption that input lines do not self-intersect.
Input |
Generalized without constraint |
Conflict |
Generalized with constraint |
Line-Line Intersection
Line-Line Intersection prevents a line from intersecting another line, with the assumption that input lines do not intersect each other.
Input |
Conflict |
Sidedness
Sidedness maintains the relative positioning of all lines and points.
Input |
Conflict |
- Results may be improved by using TopologyBuilder, GeometryValidator, or Intersector transformers prior to the SherbendGeneralizer.
- To generalize individual features with no constraints, use the Generalizer.
- The Generalizer’s generalizing algorithms may be useful before or after the SherbendGeneralizer to further reduce vertex density.
- The SherbendGeneralizer does not accept area geometry. A GeometryCoercer or TopologyBuilder may be useful for pre-processing features.
- Constraint checking is a highly time-intensive operation. Use constraints only as necessary.
Lines to be generalized. They are assumed to not self-intersect or intersect with another line or point.
Areas are not supported and should be converted to lines prior to processing.
(Optional) Point features to be considered for the sidedness constraint.
Features generalized as specified in parameters. Attributes are kept.
Bends that, if generalized, would violate the selected constraints.
Features with non-line, invalid or otherwise non-generalizable geometry are output here.
Group By |
Only lines and points in the same group are subject to constraint checking. If no group is specified, all lines and points are placed in the same group. |
Complete Groups |
![]() There are two typical reasons for using When Group Changes (Advanced) . The first is incoming data that is intended to be processed in groups (and is already so ordered). In this case, the structure dictates Group By usage - not performance considerations. The second possible reason is potential performance gains. Performance gains are most likely when the data is already sorted (or read using a SQL ORDER BY statement) since less work is required of FME. If the data needs ordering, it can be sorted in the workspace (though the added processing overhead may negate any gains). Sorting becomes more difficult according to the number of data streams. Multiple streams of data could be almost impossible to sort into the correct order, since all features matching a Group By value need to arrive before any features (of any feature type or dataset) belonging to the next group. In this case, using Group By with When All Features Received may be the equivalent and simpler approach. Note Multiple feature types and features from multiple datasets will not generally naturally occur in the correct order.
Diameter |
Specify the diameter of the reference circle in ground units. See How does it work?. |
Spatial Constraints |
Select any constraints to be applied:
See Spatial Constraints. |
Preserve Endpoints in Closed Lines |
Select a method for handling the endpoints of closed lines:
Yes |
Dependencies | None |
Aliases | |
History |
Search for all results about the SherbendGeneralizer on the FME Community.
