FME Transformers: 2025.1
RabbitMQConnector
Connects to a RabbitMQ AMQP 0-9-1 broker to send and receive messages.
- Producing messages to RabbitMQ
- Aggregation of data from RabbitMQ topics and other message streams
- Interoperability with Big Data analytics platforms
The output of this transformer will vary depending on the action performed. Message data and metadata are presented as feature attributes.
- After a Receive action, output features represent messages received from the broker.
- After a Send action, output features represent messages sent to the broker.
- After a Count action, output the number of messages in a queue.
- After an Acknowledge action, set messages marked as acknowledged. There are no output features.
On a Receive action, heartbeat features will be output through this port. Heartbeat features will have two output attributes:
- _heartbeat_id: Integer starting at 0. This is a unique identifier for each heartbeat feature output from this port.
- _heartbeat_counter: Integer starting at 0 that resets whenever the connector receives a new message and a new period of inactivity begins. This counter represents the number of consecutive heartbeat features.
See Heartbeat for more details.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Credential Source |
Using a web connection integrates best with FME, but in some cases, you may wish to use one of the other sources.
Account |
Available when the credential source is Web Connection. To create a RabbitMQ connection, click the Account drop-down box and select Add Web Connection.... The connection can then be managed via Tools > FME Options > Web Connections. |
Host |
The endpoint of the RabbitMQ broker. |
Virtual Host |
The name of the virtual host used for multi-tenant brokers. Default is /. |
Broker Port |
The port to connect to the broker. Default is 5672. |
Web Port |
The port to connect to the RabbitMQ HTTP API. This is the same port for the admin web GUI. Default is 15672 |
Enable SSL/TLS |
Whether to use a secure connection when connecting to the broker. |
Verify Certificates |
Whether to verify SSL/TLS certificates. Only choose No if there are expected certificate errors. |
User Name, Password |
The username and password to use when connecting to the broker. |
Action |
The type of operation to perform. Choices are:
Acknowledge Options
Receiving Connector Id |
The _connector_id attribute received from the Receive Action. Used for determining the message to acknowledge. |
Delivery Tag |
The _delivery_tag attribute received from the Receive Action. Used for determining the message to acknowledge. |
Multiple Messages |
If Yes, acknowledge all messages prior to the current message. |
Count Messages Options
Queue |
The queue to count waiting messages. Note that when a Count Messages action follows a Receive action, the number of messages returned may be one less than the actual number. |
Routing
Exchange Type |
The exchange
Exchange |
The exchange name consists of a non-empty sequence of these characters: letters, digits, hyphen, underscore, period, or colon. |
Routing Key |
The name used to route messages from exchanges to queues. |
Queue |
The queue name. If empty, the broker will create a unique queue name. |
Queue Type
The type of RabbitMQ queue:
Receive Options
Receive Mode |
Two message receiving options are available:
Batch Size |
In Batch mode, specifies the number of messages to read per batch. |
Heartbeat
When Action is set to Receive, a heartbeat feature is output through the Heartbeat port after a period of inactivity. The length of this period is determined by the following parameters:
Interval |
The period of inactivity before a heartbeat feature is emitted, in units specified by the Time Unit parameter. Defaults to 1. |
Time Unit |
The unit for Interval.
Defaults to Hours. |
Advanced Properties
Auto Acknowledge |
Three Acknowledgment modes are available. Default is No.
This option is disabled if the Queue Type is Stream, as consumed messages will always be acknowledged. |
Declare Exchange |
Whether to declare the exchange. |
Exchange Properties |
Properties to apply to the exchange:
Queue Properties |
Properties to apply to the queue when Queue Type is Classic:
For more information on RabbitMQ queues see: https://www.rabbitmq.com/queues.html |
Offset Mode |
If Queue Type is Stream, specify where in the stream to begin reading messages.
Offset Value |
If Offset Mode is Value, specify either an integer representing an offset of an existing message in the stream queue, or an ‘Interval’ string that begins with an integer and ends with a valid unit (Y,M,D,h,m,s). See the Offset and Interval options in https://www.rabbitmq.com/docs/streams#consuming for details. |
Offset Timestamp |
If Offset Mode is Timestamp, specify a date and time representing a point in time to start reading messages from. This date and time must be specified in Coordinated Universal Time (UTC). See the Timestamp option in https://www.rabbitmq.com/docs/streams#consuming for details. |
Stream Properties |
Properties to apply to the queue when Queue Type is Stream:
If a queue already exists, specified properties must match existing properties. For more information on RabbitMQ stream queue properties, see: https://www.rabbitmq.com/docs/streams#declaring. |
Routing
Exchange Type |
The exchange
Exchange |
Routing Key |
The name used to route messages from exchanges to queues. If Exchange Type is Direct and Exchange is empty, Declare Queue must be Yes and the Routing Key must be identical to Queue. |
Send Options
Payload |
The content of the message. This is often JSON, but can be any string, binary, integer or floating-point value. |
Delivery Mode |
Advanced Properties
Declare Exchange |
Declare Queue |
Whether to declare the queue. |
Queue |
The queue to use. |
Queue Type |
Queue Properties |
For more information on RabbitMQ queues, see: https://www.rabbitmq.com/queues.html |
Message Properties |
Additional message properties settable. The following keys are valid:
Stream Properties
Available attributes vary according to the selected Action.
Attributes to Add |
Select any available attributes to be included on the output features:
| Dependencies | |
| History | Released FME 2019.0 |
Search for all results about the RabbitMQConnector on the FME Community.
