FME Transformers: 2025.1 BETA
Categories
Integrations
Web
Web
Geocoder
Uses various external web services to convert addresses to latitude/longitude coordinates, or to find the closest addresses to latitude/longitude coordinates (reverse geocode). Some services have additional information available, such as time zone or elevation.
Jump to Configuration
  • Find coordinates and create geometry for a list of street addresses
  • Find addresses that match coordinates
The Geocoder provides a single interface to numerous geocoding web services. Once a service is selected, the appropriate parameters are presented, including connection credentials and the expected attributes the service needs to perform geocoding.
As features pass through the transformer, these attributes are passed to the service, and the results retrieved.
If the feature is successfully matched by the service, the results (attributes and/or geometry) are added to the feature and it is output through the Output port.
If the feature geocoding fails for any reason (including addresses not found, invalid coordinates, or failed credential authentication), it is output through the <Rejected> port.
Modes
The Geocoder can perform a variety of tasks, dependent upon which service you choose to use. Each service will provide one or more of these modes of geocoding:
Forward Street Address Geocoding
Single free form street address to latitude/longitude values, for example:
"7445, 132nd Street, Surrey, BC, V3W 1J8"
Discrete street address elements to latitude/longitude values, for example:
"7445"
"132nd"
"Street"
"Surrey"
"BC"
"V3W 1J8"
Forward Address Batch Geocoding
Single free-form street address or discrete street address elements to latitude/longitude values, submitted as a batch request. Batch geocoding requests are not submitted concurrently.
Forward IP Address Geocoding
IP address string to latitude/longitude values
Forward Address Geocoding to Service ID
Single free-form street address or discrete street address elements to a service-specific identifier
Reverse Street Address Geocoding
Latitude/longitude values to a single street address string
Reverse Address Batch Geocoding
Latitude/longitude values to a single street address string, submitted as a batch request. Batch geocoding requests are not submitted concurrently.
Reverse Elevation Geocoding
Latitude/longitude values to elevation in meters
Reverse Timezone Geocoding
Latitude/longitude values to timezone code, name and offset
Reverse Street Address Geocoding from Service ID
Service specific lookup key to a single street address string
The geocoding service result is stored in output feature attributes, feature geometry, or both. For example, latitude/longitude output is represented on the feature as a point geometry, and also as ‘_latitude’ and ‘_longitude’ attributes.
  • Many services have restrictions on how their results may be used or displayed. Check with your chosen service for terms and conditions. See available services.
  • The expected input address format varies between services. See documentation provided by your chosen service for details.
  • If you need to create address strings for your chosen service, you can build them right in the Geocoder using the Text Editor, or consider using the AttributeManager to construct them as persistent attributes.
This is a complete list of possible parameters for all services accessed by the Geocoder. Only the service-specific required parameters will be shown in the transformer once a service has been chosen.
Geocoding Services
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies External geocoding web service(s)
Aliases
History This FME Package transformer replaces the Geocoder originally shipped with FME 2021.1 and older versions.
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the Geocoder on the FME Community.
