FME Transformers: 2025.1 BETA
Categories
3D
3D
Calculated Values
Coordinates
Data Quality
Strings
Related Transformers
CoordinateExtractor
DimensionExtractor
ElevationExtractor
Extracts a feature’s first z coordinate value, storing it in an attribute.
Jump to Configuration
  • Extracting elevations from geometry to an attribute for further processing.
The ElevationExtractor receives any type of geometry and extracts the z coordinate value of the feature’s first coordinate into an attribute.
If the input feature is 2D, the Elevation output attribute will receive a value of zero (0).
Rasters, including elevation models, will also receive an elevation value of zero (0).
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the ElevationExtractor on the FME Community.
