FME Transformers: 2025.1 BETA
Categories
Coordinates
Integrations
Related Transformers
AttributeReprojector
CommonLocalReprojector
CsmapReprojector
EsriReprojector
GridInQuestIIReprojector
GtransAttributeReprojector
GtransReprojector
PROJAttributeReprojector
PROJReprojector
ReframeReprojector
ReprojectAngleCalculator
ReprojectLengthCalculator
Reprojector
CsmapAttributeReprojector
Reprojects coordinates stored as attributes from one coordinate system to another using the CS-MAP library.
Jump to Configuration
  • Reprojecting coordinates stored as attributes when explicitly using the CS-Map library is desired
  • Reprojecting coordinates stored as attributes with Z values
  • Performing reprojections with finer control than the AttributeReprojector transformer provides
The CsmapAttributeReprojector accepts any feature. The user specifies attributes containing X, Y, and optionally Z coordinates, and supplies both the Source and Destination Coordinate Systems.
The transformer reprojects the coordinates according to these selections, using the CS-Map library, and updates the X, Y, and Z Attributes to the new values. The original values are overwritten.
This transformer does not alter the feature’s geometry – only the values of the selected X, Y, and Z Attributes (if they contain coordinate values) are changed.
Accurate results depend on the user’s correct selection of the source coordinate system.
The CS-Map library is FME’s default library, and so is generally used for most transformations. Using this transformer explicitly ensures that this library is used, and also provides options for handing Z (vertical) values.
Dynamic Coordinate Systems
Features may be reprojected to a dynamic Destination Coordinate System - that is, a local coordinate system that is created specifically for each individual feature. This is often used for tasks such as taking measurements or creating geometry in meters or other ground units, on data with geographic (latitude and longitude) coordinates.
There are two types available:
  • _AZMEA_ (Dynamic Reprojection Equal Area) - Better for preserving area accuracy
  • _AZMED_ (Dynamic Reprojection Equal Distance) - Better for preserving distance accuracy
In either case, the input feature is reprojected to a local coordinate system centered on its bounding box. Though all the output features will be centered on a common origin (with the exception of features located very near the poles) and appear stacked on top of each other, each one retains the specifics of its reprojection (and so original position), and can be safely reprojected back into a projected or geographic coordinate system.
Note that Z values are not considered, so areas or distances are best preserved for geometry at an ellipsoid height of 0 meters.
Note  To calculate and reproject to a single AZMED or AZMEA coordinate system that encompasses all input features, consider using the CommonLocalReprojector.
Geographic Transformations
Geographic Transformations control how coordinates are converted between different datums.
The default is <Auto> (or blank), which will look for an appropriate transformation between datums, if one is needed.
If an explicitly selected pair of coordinate systems has one or more geographic transformations available, they will be provided for explicit selection.
If set to <None>, the NULL_FME transformation will be used which does not alter the value of any coordinates.
  • FME also has a Workspace Parameter, Reprojection Engine, that may be set to either FME (CS-Map) or Esri. This transformer will override this parameter setting.
  • The AttributeReprojector provides similar functionality, and will use the default library (CS-Map or Esri) set in FME. It does not handle z values.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies Some reprojections may require additional grid files.
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the CsmapAttributeReprojector on the FME Community.
