FME Transformers: 2025.1 BETA
CoordinateSystemRemover
Removes the assigned coordinate system from features, without modifying geometry or coordinates.
- Removing incorrect or unnecessary coordinate system designations
- Troubleshooting coordinate system issues
The CoordinateSystemRemover receives any feature and removes any assigned coordinate system from it. No geometry is modified, and data is not reprojected.
In this example, we have a raster that appears to be in a local coordinate system but has an assigned coordinate system of UTM83-10.
The raster is routed into a CoordinateSystemRemover, which has no parameters to set.
The output feature has its coordinate system removed, but its coordinates are unchanged.
- A coordinate system can be replaced without altering the geometry or coordinates by using a CoordinateSystemSetter.
Possession of a coordinate system definition doesn’t control whether writers create coordinate system-related metadata such as wld or prj files. These are controlled by writer parameters
Coordinate System Support
Library |
FME (default) or Esri |
Library (External Links) |
Sweden |
Sweden |
Switzerland |
Features with any assigned coordinate system removed, with unaltered geometry and coordinates.
Dependencies | None |
Aliases | |
History |
Search for all results about the CoordinateSystemRemover on the FME Community.
