FME Transformers: 2025.1
Categories
Integrations
Web
Web
Workflows
Related Transformers
GoogleDriveConnector
S3Connector
SharePointOnlineConnector
AutodeskDocsConnector
Connects to Autodesk Docs, Autodesk Construction Cloud or Autodesk Build to manage files and folders.
Jump to Configuration
  • Managing files on Autodesk Docs by uploading, downloading, and deleting files and folders
  • Transferring file contents into or out of an attribute in FME
  • Retrieving file and folder names, paths, and other information from Autodesk Docs to use elsewhere in a workspace.
The AutodeskDocsConnector uses your Autodesk account credentials to perform various management tasks on Autodesk Docs:
Action Task
Delete
Delete files and folders.
Download
Download a file or folder to an attribute, file, or folder.
List
List the item details for the contents of a folder.
Upload
Upload a file, folder, or the contents of an attribute.
Once valid account credentials have been provided, you may browse to available content for the selected Action.
Authentication
Autodesk authentication has two components -
  • One-time addition of FME in the Autodesk App Store.
  • Creating a Web Connection in FME for recurring authentication.
See Using Web Connections and Adding FME through the Autodesk App Store for Use in the AutodeskDocsConnector.
  • This transformer cannot move or copy files between different locations. Consider using multiple connectors for these tasks, by downloading files/folders and re-uploading them to a new location.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies Autodesk Docs, Autodesk Construction Cloud (ACC), or Autodesk Build Account, recommended to have a Forge App with access to the Data Management API
Aliases AutodeskBIM360DocsConnector AutodeskConstructionCloudConnector
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the AutodeskDocsConnector on the FME Community.
