FME Transformers: 2025.1
Categories
Database
Strings
Related Transformers
StringReplacer
AttributeTrimmer
Removes specified leading and trailing characters from selected attributes.
Jump to Configuration
  • Cleaning attribute data
  • Removing white space (non-printing characters) from attribute values
The AttributeTrimmer removes specific characters from the beginning and/or end of chosen attribute values.
It does not match specific character patterns, rather, as long as the next character is included in the list of Trim Characters, it will continue to remove them until it encounters a character that is not in the list.
For example, suppose the attribute to trim had the value "This is a test" and Trim Type was set to Both (trimming from both the beginning and end of the value).
  • If Trim Characters had the value "hit", the result would be "This is a tes".
  • If Trim Characters had the value "HhIiTt", the result would be "s is a tes".
Trim Characters may be alphanumeric, and can include control characters. If Trim Characters is left blank (unspecified), “white space” will be removed - non-printing characters such as spaces, tabs, newlines, and carriage returns.
The attributes are output with any matching characters trimmed. Attributes that do not have matching Trim Characters are output untouched.
  • To trim a specific prefix or suffix, or match any consistent string pattern, consider using the StringReplacer.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies
Aliases StringTrimmer
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the AttributeTrimmer on the FME Community.
