FME Transformers: 2025.1 BETA
Categories
Attributes
Strings
Related Transformers
AttributeDereferencer
AttributeExposer
AttributeManager
AttributePivoter
ListSorter
AttributeExploder
Creates value pairs (attribute name and attribute value) for every attribute on a feature, and either adds them to a list attribute or creates new features (one for each pair) with new attributes containing both values.
In either case, original attributes and geometry may be kept or discarded.
Jump to Configuration
  • Transposing or manipulating tabular data (such as spreadsheets)
  • Melting data
  • Extracting the attribute schema from features for use in dynamic translation attribute mappings
  • Extracting the attribute schema from features to write as metadata/documentation
  • Preparing data for charts and reports
The AttributeExploder receives features with attributes, and extracts both the attribute names and their values. It can do one of two things with them (the Exploding Type) - either create multiple new features (one for each attribute), or add the information to the original feature as a list attribute.
The following examples demonstrate both Exploding Types, as they apply to a single feature. Note that in both cases, extra attributes that are normally unexposed are also exploded, including reader and internal fme_ attributes.
You may opt to either keep or discard the original attributes and geometry - in these examples, they are discarded.
Exploding Type: Features
If the attributes are exploded into Features, each input feature will become many - one for every attribute in the original feature. The new features will have both the original attribute names and values added as new attributes. Below, we use the default new attribute names _attr_name and _attr_value.
One (1) feature becomes twelve (12).
In the case of a spreadsheet, where a row is considered a single feature, this is the equivalent of exploding every cell into its own feature.
Exploding Type: List
If the attributes are exploded into a List, a new list attribute is added to the original feature.
The attribute names and values are added as list elements.
One (1) feature in produces one (1) feature out, with a list attribute.
Excluding Attributes
AttributeExploder processes all attributes on incoming features, including fme_ and format attributes. It is possible to ignore attributes using the Ignore Attributes Containing parameter.
Enter a regular expression, and matching attributes will be ignored.
For example, if the source data is CSV, you could use the regular expression ^fme_|^multi_|^csv_ to ignore any attributes starting with fme_, multi_, or csv_.
  • The AttributeExploder is commonly used in manipulating tabular data, from simple transposition to more complex tasks. See articles on the FME Community for detailed examples.
  • To unmelt (reverse melt) data, see the AttributeCreator (alias UnMelter).
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases Melter
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the AttributeExploder on the FME Community.
