Oracle Feature Representation
Features read from Oracle consist of a series of attribute values and geometry data.
In addition to the generic FME feature attributes that FME Workbench adds to all features (see About Feature Attributes), Oracle uses the following special attribute and trait names:
Attribute/Trait Name
Contents
oracle_type
This attribute stores the type of geometric entity stored within the feature. The valid values are:
  • oracle_arc
  • oracle_area
  • oracle_circle
  • oracle_collection
  • oracle_line
  • oracle_multiline
  • oracle_multipoint
  • oracle_multipoly
  • oracle_multisolid
  • oracle_multisurface
  • oracle_nil
  • oracle_point
  • oracle_rectangle
  • oracle_solid
  • oracle_surface
oracle_srid
For the Oracle reader, this attribute is set to the SRID value of the geometry being read. If the SRID value is null, oracle_srid is not set on the feature. The SRID value on the first feature read is used to look up a coordinate system in FME, which is then set on all the subsequent features read, even if their SRID values conflict with the first SRID value.
For the Oracle writer, oracle_srid specifies the SRID of the geometry being written on a per-feature-type (table) basis. It overrides the coordinate system set on the writer.
Note  This attribute is not used by the Oracle writer when writing vector geometry.
Coordsys
This trait stores the FME coordinate system name that corresponds to the Oracle SRID. This is only present when Handle Multiple Spatial Columns is enabled.
Features read from, or written to, Oracle also have an attribute for each column in the database table. The feature attribute name will be the same as the source or destination column name. The attribute and column names are case-sensitive.
