Oracle Writer Parameters
Database formats include a Database Connection parameter that defines and stores authentication information. For general information about sharing database connections, please see Using Database Connections. Note that Database Connection parameters differ slightly, depending on context and/or database format. |
Connection From the Connection parameter in a database format, you can do one of the following:
The name of the Oracle Workspace Manager workspace that will be used by the writer. All tables will be written using the same workspace. If this parameter is omitted, or left blank, the default LIVE workspace will be used.
If this parameter is checked (default), the Oracle database connection remains open for other requestors. A persistent connection is useful for workspaces that are long-running, or published using FME Flow.
If this parameter is unchecked, the connection to the Oracle database is closed as soon as possible after data processing is complete.
Case Conversion
These parameters change the case of all feature type and attribute names in the output.
- UPPERCASE – Change all feature type names to uppercase text.
- lowercase – Change all feature type names to lowercase text.
- None – Do not make changes to any feature type names.
- UPPERCASE – Change all attribute names to uppercase text.
- lowercase – Change all attribute names to lowercase text.
- None – Do not make changes to any attribute names.
Spatial
Indicates whether or not spatial indexes are to be created as part of the data load.
If No is selected, no spatial index creation will be done.
These values apply to the entire layer – features with coordinate values outside this range will not be correctly indexed.
Oracle Spatial Object directly supports composite surfaces, 3D polygons and rectangles. Writing of 3D surfaces and solids is available only for Oracle 11g and above. If the Oracle Spatial Object writer detects an older version of Oracle Database, surface features will automatically be downgraded to a 2D representation prior to writing.
Minimum and Maximum Z Ordinate
Specifies the minimum and maximum Z values expected in the dataset.
Directs the writer to write measures to the destination table. When this option is checked and the incoming feature does not have any measures, then null values are written. This option applies when writing to existing tables.
However, when creating new tables, the writer takes care of everything including writing to the metadata table. The above parameter is ignored when writing to points, multipoints, multiareas and heterogeneous collections, as Oracle does not support measures for these geometries.
Minimum and Maximum M Ordinate
Specifies the minimum and the maximum measure values expected in the dataset.
Advanced
This setting enables the creation of tables without data features.
- No - Tables are only created when receiving data features.
- Yes - Tables are created without data features if possible.
This parameter, also known as chunk size, specifies how many features the writer transmits over the network at a time to the database. Features will get cached in memory until this feature count is reached, and then they will be transmitted as a single chunk to the database. Features Per Transaction is normally a multiple of this parameter. Once all chunks in a transaction are received by the database, the transaction is committed.
This parameter has a significant impact on performance. When the database server is physically remote, round-trip time for data transmission can cause bottlenecks in data loading. To reduce network round-trip time, increase the value of this parameter.
Tip This parameter is often confused with Features Per Transaction. Each bulk write is a part of exactly one transaction. So, if Bulk Write Size is greater than Features Per Transaction, then it is automatically reset to the value of the latter.
This parameter specifies how many features are written to the database before they are committed. It is usually a multiple of Bulk Write Size.
Note that the written feature count is at the writer level and not the feature type level.
- If this parameter is set to a small number: when a transaction fails, only a small number of features (for example, all features in that transaction) get rolled back.
- If this parameter is set to a large number: when a transaction fails, a large number of features get rolled back.
For optimal performance, make Features Per Transaction large (but not excessive), and set Bulk Write Size to the same value.
This parameter allows for the execution of SQL statements before writing to a table. For example, it may be necessary to clean up a table before attempting to write to it. The statements will be executed only when the first feature arrives at the writer.
For detailed information about SQL functions, click the corresponding menu item in the .
Available menu options depend on the format.
Multiple SQL commands can be delimited by a character specified using the FME_SQL_DELIMITER directive, embedded at the beginning of the SQL block. The single character following this directive will be used to split the SQL block into SQL statements, which will then be sent to the database for execution. Note: Include a space before the character.
For example:
FME_SQL_DELIMITER ; DELETE FROM instructors ; DELETE FROM people WHERE LastName='Doe' AND FirstName='John'
Multiple delimiters are not allowed and the delimiter character will be stripped before being sent to the database.
Any errors occurring during the execution of these SQL statements will normally terminate the reader or writer (depending on where the SQL statement is executed) with an error. If the specified statement is preceded by a hyphen (“-”), such errors are ignored.
This parameter allows for the execution of SQL statements after a set of tables has been written. For example, it may be necessary to clean up a temporary view after creating it.
For example:
This parameter specifies how the writer proceeds when a problem arises while converting a value from one of a feature’s attributes to an Oracle column value.
Examples of such problems would be the truncation of a string value to fit into the target character column, an error in writing a non-numeric attribute to a numeric column, or an error converting an FME geometry into an SDO_GEOMETRY value.
- Yes – The conversion errors result in warnings. Features are logged and dropped from the translation.
- No – The writer will silently write null values or truncated strings when conversion errors occur.
- Warn – The writer warns and writes null values or truncated strings when conversion errors occur.
If this parameter is set to Yes, feature geometry will be written from an aggregate. This aggregate must contain individual geometries, namely that each part is independent from the others and is its own complete geometry. Each part geometry of the aggregate must have a name:
- If the aggregate contains geometries with names that match the spatial columns of the table being written, the geometries will be written to the appropriate columns.
- If the aggregate does not contain a name that matches a spatial column on the table being written, a null value will be written in INSERT mode. Geometry-specific data normally read from feature attributes will be read from geometry traits instead.
When using this feature, the geometry column cannot be specified and the table must already exist.
