FME Form: 2025.1
                                                You can create a workspace from the Start tab, under Get Started:
New
Opens a blank workspace file. You can build a workspace and save it to a file later.
Open
Opens a file dialog that allows you to:
- Open an existing workspace. To limit the file dialog selection to workspace files, specify FME Workbench Files.
- Begin creating a workspace from a data file. To allow the file dialog to locate data files, specify All Files.
Create a workspace from an example.
FME Flow
Opens the Download from FME Flow dialog.
Data Virtualization
Opens the Download from FME Flow Data Virtualization dialog.
AI Assist
Opens the AI Assist window.
To Understand Your New Workspace
- See Understanding Schema.
