FME Flow: 2025.1 BETA
Install the FME Flow Database
Install a PostgreSQL FME Flow Database on a separate machine on your network.
Note  Complete this step only if you wish to install, on a separate machine, a PostgreSQL database that is included with the FME Flow installer, and do not wish to configure the FME Flow Database on your own database server. For more information, see Provide a Database Server.
Start the FME Flow installer.
On the Installation Extractor dialog, specify a Destination folder in which to extract installation files. Note that this folder only specifies where installation files are extracted—it does not specify where FME Flow program files are installed. That location is specified later in the installer.
  • Remove these files to save disk space.
Click Install.
Choose Setup Type
Custom Setup
Specify FME Flow Database. Unselect all other components.
Note  The FME Flow installer does not distinguish between the settings Will be installed on local hard drive and Entire feature will be installed on local hard drive. In either case, the entire feature is installed on the local drive.
Destination Folder
Specify the installation directory for the FME Flow Database.
Database Parameters
  • Install the FME Flow Database files to: Specify a directory to install the database files.
  • Port: Specify the port that the database will listen on. Port 7082 is the default.
Database User
Specify a User Name (defaults to fmeflow) and Password for the database user account.
When specifying User Name and Password, keep in mind the following:
  • Do not specify User Namepostgres. This name corresponds to the PostgreSQL master user. If the corresponding passwords do not match, the database will not install.
  • Password must not contain any single quote (') characters.
  • The specified Password is encrypted in FME Flow installation files.
  • Take note of the User Name and Password that you specified. You may need to reference it later.
What's Next?
