FME Transformers: 2025.0
PythonCaller
Executes a user-supplied Python script to manipulate features.
- Tasks where a transformer is not available
- Using external modules for processing
- Performing complex manipulations on list attributes
The PythonCaller executes a Python script to manipulate features.
When a specialized task is required, such as custom statistical analysis of an attribute, but FME Workbench does not provide a transformer suited to the task, a Python script can perform specialized and complex operations on a feature's geometry, attributes, and coordinate system.
Access is provided via the FME Objects Python API.
Using Python to perform arbitrary operations on features is a powerful aspect of FME Workbench. However, the logic introduced into a workspace is less visible and can therefore be more difficult to maintain than logic built using FME Workbench’s built-in transformers. It is recommended that other transformers be used when possible instead of Python scripts.
Class Interface
The PythonCaller can interface with a class defined in a Python script.
The supplied script contains a class called FeatureProcessor, which inherits from fme.BaseTransformer. This is a base class that represents the interface expected by the FME infrastructure. See the FME Python module documentation for more information.
The calling sequence on the methods defined in a class depends on which mode the PythonCaller is in. There are two modes - Standard and Group Processing.
Standard Mode
This is the operation mode when no attributes are set in the Group By parameter. Most uses of the PythonCaller will use standard mode processing. In this mode, the PythonCaller will have the following calling sequence on a class:
- __init__() - Called once, whether or not any features are processed.
- input() - Called for each FMEFeature that comes into the input port.
- close() - Called once, after all features are processed (when no more FMEFeatures remain). If no features are processed, the close() method will still be called.
Features that need to continue through the workspace for further processing must be explicitly written out using the pyoutput() method. When using the pyoutput() method, it is recommended to set the output_tag argument to PYOUTPUT.
As of FME 2023.1, bulk mode is enabled by default for the PythonCaller. This allows for significant performance gains when processing large numbers of features. In bulk mode, FME will pass features to the `input()` method which come from a feature table object. The following conditions must be met:
- features passed into the input() method cannot be copied or cached for later use
- features cannot be read or modified after being passed to the pyoutput() method
- Only features passed into the transformer can be output from the transformer. Newly instantiated FMEFeature() objects should not be output from the transformer. Not every feature passed into the transformer needs to be output from the transformer.
- Group processing must not be enabled
Violations will cause undefined behavior. If PythonCaller usage does not meet these requirements, bulk mode should be disabled by altering the has_support_for() method to return False when the support_type argument is equal to fmeobjects.FME_SUPPORT_FEATURE_TABLE_SHIM.
When the PythonCaller implementation processes incoming FMEFeatures one at a time, the pyoutput() method is to be called once per incoming FMEFeature in the input() method.
When the PythonCaller implementation requires knowledge of multiple FMEFeatures to process features, the incoming FMEFeatures can be stored in a list, then processed and written out through pyoutput() in the close() method.
The example below calculates the total area of all the features processed and then outputs all the features with a new attribute containing the total area. Note that since features are cached for later use, bulk mode should not be enabled.
Group Processing Mode
This is the feature processing mode used when one or more attributes are set in the Group By parameter. When using this mode, bulk mode must be disabled by altering the has_support_for() method to return False when the support_type argument is equal to fmeobjects.FME_SUPPORT_FEATURE_TABLE_SHIM.
- input() - Called for each FMEFeature in a group.
- process_group() - Called after all FMEFeatures in a group have been sent to input(). After this is called and executed, PythonCaller will send the next group of FMEFeatures to input() and then call process_group() again. This is repeated until all groups have been exhausted.
- close() - Called once, after all rounds of input() and process_group() have been called to process all incoming features (when no more FMEFeatures remain). If no features are processed, the close() method will still be called.
In this mode, the class interface will be working on groups of FMEFeatures. The incoming FMEFeatures must be stored in a list class member variable, then processed and written out through pyoutput() in the process_group() method. After processing is complete in process_group(), all class member variables should be cleared for the next round of group by handling. In the next round, FMEFeatures of the next group are passed through input() calls followed again by process_group(). This is repeated until all the groups are exhausted.
The example below calculates the total area of all features grouped by the _shape attribute and then outputs all the features with a new attribute containing the total area for each group:
Feature Rejection
Regardless of processing mode, if there are input features that cause operations to fail, they can be sent to the <Rejected> port by using the reject_feature() method defined in the FeatureProcessor class.
Script Editing
A PythonCaller transformer can call scripts that are stored in the transformer itself or scripts that are stored globally for the entire workspace:
- To store a Python script with a specific PythonCaller transformer, use the Python Script parameter in the transformer.
- To store a Python script globally, click the Advanced Workspace Parameter in the Navigator, and double-click Startup Python Script. Storing scripts globally has the advantage of keeping the Python logic centralized, which makes editing and maintenance easier. This is useful when there are multiple PythonCaller transformers throughout the workspace that use the same script. For more information, see Startup and Shutdown Python Scripts in the FME Workbench help.
FME can access .py modules that are stored on the file system, including modules in external Python libraries. Use the Python "import" command to load these modules. FME will search both the standard Python module locations and the workspace location to find the module to be imported.
Features to be manipulated.
Features, including any modifications made.
Features that have been rejected using the reject_feature() method defined in the FeatureProcessor class. An fme_rejection_code attribute will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the rejection.
Group By |
If the Group By parameter is set to a set of attributes, one feature per group will be produced. |
Complete Groups |
Class to Process Features |
The name of the Python Class within the script that PythonCaller will use to begin execution. For the above examples, set this parameter to FeatureProcessor. |
Python Script |
The Python script to be executed. When the Python script is stored as the Startup Python Script for the workspace, leave this parameter blank. |
Attributes to Expose |
Exposes attributes so they can be used elsewhere in the workspace. Attribute names may be entered directly or provided in the Enter Values for Attributes to Expose dialog accessed via the ellipsis button, where data type may also be specified. For more information on exposed and unexposed attributes, see Understanding Feature Types and Attributes. Used to expose any attributes that are created by the Python script being executed so they can be used by other transformers. |
Attributes to Hide |
Hides any attributes that may be removed by the Python script being executed. Other transformers will not be able to use these attributes. |
Lists to Hide |
Hides any lists that may be removed by the Python script being executed. Other transformers will not be able to use these lists. Note that if you select to hide a list, your selection will include any list attributes or nested lists. For example, if you select to hide a list called list{} then list{}.attr or list{}.sublist{} will also be hidden. |
Feature-Based or Group-Based, conditional on Python script |
Conditional on Python script |
| Dependencies |
An FME installation includes a Python version 3.13 interpreter. The FME Objects Python API supports Python 3.9 - 3.13. The Python interpreter used by FME to execute Python scripts is controlled by the Python Compatibility workspace parameter . FME will load the latest available Python interpreter matching that parameter. For more information, see FME Workbench help. If you would like to install a third-party package for use by Python in FME, see Installing Python Packages to FME Form in FME Workbench help. |
Search for all results about the PythonCaller on the FME Community.
