FME Transformers: 2025.0
HullReplacer
Replaces feature geometry with a convex or concave hull around the feature.
Generating hulls around individual features
The HullReplacer receives features with any geometry type and individually replaces their geometry either a Convex or Concave hull.
A convex hull is a polygon covering the extents of the feature, where no interior angle is greater than 180 degrees. It resembles an elastic band surrounding the feature.
A concave hull (or alpha hull) has no restrictions on angle and may follow the general shape of the feature more tightly. It is calculated using the Alpha Value parameter and can have multiple parts and donuts.
If an output hull has zero area (the hull of a single point or vertical line, for example), it will become a point or line as appropriate.
3D hulls may be generated when input features are either 3D or a mix of 3D and 2D. If mixed, 2D features are assigned a default Z value.
Concave hulls and alpha values
Concave hulls vary in shape. They are calculated by first triangulating the dataset, then measuring the circumradius of the resulting triangles (the radius of a circle that touches all three points of the triangle). Triangles that are larger than the specified Alpha Value are discarded, and the rest are dissolved to form the hull. Measurements are in ground units.
If the Alpha Value is explicitly specified, it is used for the calculation. If it is zero (0) or not specified, the alpha is approximated as the smallest value that produces a single area. If the alpha is too small it may return a null geometry. Larger numbers generally produce larger areas, and a large enough alpha value produces the same result as a convex hull.
See Examples below to see the effect of varying the Alpha Value.
Geometries that are farther away than Alpha Value from the rest of the geometries may be discarded if they do not constitute a valid area on their own.
Concave hull generation works best with points, but line and area geometries will be accepted and converted to points if input.
In this example, we want to generate both convex and concave hulls around a point cloud. Note that the bottom left corner of the data has an irregular edge, the result of LiDAR coverage along a coastline.
A point cloud is a single feature. There is a set of specialized point cloud transformers that operate on individual points, but other transformers generally treat their geometry as their rectangular footprint (bounding box).
To create a hull that honors the irregular edge, the point cloud is first routed into a PointCloudToPointCoercer and then on to a HullReplacer.
In the parameters dialog, Output Geometry is set to Single Multipoint. Only one feature is output via the Coerced output port.
The resulting multipoint feature is no longer treated as a point cloud. Note that this will result in much longer processing times.
In the parameters dialog of the HullReplacer, Hull Type is set to Convex (), and Output Dimension is changed from Automatic to 2D to ensure the hull is a footprint.
The resulting 2D hull honors the irregular boundary of the data. It replaces the multipoint geometry.
If Hull Type is Concave )( and Alpha Value is left blank (calculating the optimal alpha to produce a single hull), a tightly fitting hull is produced. Processing time is much longer.
In this example, we will generate a series of concave hulls for a set of property addresses while varying alpha values.
The input features are in a UTM83-10 coordinate system, with ground units in meters, and so the alpha value represents a measurement in meters as well.
Alpha Value |
Concave Hull |
10 - Too small for useful results. |
50 - Tightly fitting, some input points fall outside alpha distance. |
Default (blank) - optimal value calculated to produce a single area. |
500 - Loosely fitting but not convex. |
10000 - Identical to the convex hull. |
- Point clouds are considered single features. To create a hull from a point cloud’s individual points, use a PointCloudToPointCoercer beforehand, setting the Output Geometry parameter to either Single Multipoint or Individual Points.
For triangulated surfaces, see the SurfaceModeller, Triangles output.
Features with 2D and/or 3D geometry.
Arcs and ellipses will be stroked prior to the calculation of the hull. Text features will be treated as points.
Hull geometry as specified in parameters. Typically a polygon, but possibly a line or a point.
Features without valid geometry are output via this port, as are features with non-numeric values for Alpha or Default Z Value.
INVALID_GEOMETRY_VERTICES
INVALID_PARAMETER_ALPHA_VALUE
INVALID_PARAMETER_DEFAULT_Z_VALUE.
Hull Type |
Select the hull type to be calculated:
Alpha Value |
When Hull Type is Concave)(, either:
See Examples above for alpha value usage. |
Output |
Select the dimensionality of the output hull:
Default Z Value |
When Output is 3D, provide a Z value to assign to converted 2D features. |
| Aliases | ConvexHullCreator ConvexHullReplacer |
Search for all results about the HullReplacer on the FME Community.
