FME Transformers: 2025.0
AzureEventHubsConnector
Accesses the Azure Event Hubs to send, receive, or checkpoint messages.
- Receive and send messages from an event hub
- Interoperability with Big Data analytics platforms
The AzureEventHubsConnector connects to Azure’s Event Hubs through the Kafka protocol using the Azure Event Hub SDK. Supports publishing, receiving messages, and checkpointing messages. A message is also known in the Azure documentation as an event.
The output of this transformer will vary depending on the action performed. Message data and metadata are presented as feature attributes.
- After a Receive action, output features represent messages received from Azure Event Hub.
- After a Send action, output features represent messages sent to Azure Event Hub.
On a Receive action, heartbeat features will be output through this port. Heartbeat features will have two output attributes:
- _heartbeat_id: Integer starting at 0. This is a unique identifier for each heartbeat feature output from this port.
- _heartbeat_counter: Integer starting at 0 that resets whenever the connector receives a new message and a new period of inactivity begins. This counter represents the number of consecutive heartbeat features.
See Heartbeat for more details.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Credential Source |
Required for authentication. Using a web connection integrates best with FME, but in some cases, you may wish to use one of the other sources.
Account |
Available when the credential source is Web Connection. To create an Azure Event Hubs connection, click the 'Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. |
Namespace |
Available when the Credential Source is Default Azure Credential. This is an Event Hubs namespace that is typically a hostname under servicebus.windows.net. |
Embedded Credentials
Event Hub Connection String |
Available when the Credential Source is Embedded. The connection string is found in the Azure Portal Event Hubs Namespace under Shared Access Policies. |
Action |
The type of operation to perform. Choices are:
Event Hubs |
The event hub to connect to. |
The checkpoint action manually checkpoints a message using the Azure Blob checkpoint store.
Checkpointing is the process of marking a user’s position within a partition event sequence. Checkpointing provides resilience when an event processor fails, and a performance benefit due to load balancing. Load balancing does not apply when receiving from a single partition.
This option is used after a Receive action if there is post-processing of a message in a workspace in which you want the checkpoint to happen later after the message is received.
Checkpoint Options
Received Message ID |
The _receive_id attribute from a receiving transformer (with the Receive action) used to identify a message to checkpoint. |
Checkpoint Store (Azure blob)
Checkpoint store is optional for the Receive action and required for the Checkpoint action. It is used to maintain a persistent store of partition checkpoint data when receiving events.
If a checkpoint store is not provided, the checkpoint will still be maintained internally in memory but events will be received without load-balancing. Users should not see any difference in connector behavior, but may encounter slower performance times as a result of no load-balancing.
When used, a checkpoint store uses an Azure storage container to store offset information. The offset information is used to start receiving at the same position at the next receive.
Container Name |
The container name for the blob store. |
Connection String |
A connection string to an Azure Storage account. Only one of Connection String or Blob Storage Account URL may be specified. |
Blob Storage Account URL |
The URI to an Azure Storage account. Blob Storage Account URL can only be used for checkpoint storage if Credential Source is Default Azure Credential or a Microsoft Azure Event Hubs Service Principal web connection is used. Only one of Connection String or Blob Storage Account URL may be specified. |
Checkpoint Interval |
(Optional) Submits a checkpoint store to Azure blob every nth message. The default checkpoints only at the end of the stream. There will always be a checkpoint at the end of a message stream. |
Receives messages from the front of the queue.
Checkpointing is also enabled, but optional.
Receive Options
Consumer Group |
The name of the consumer group to view the event hub stream. Consumer groups are created in the Azure portal. The default is ‘$Default’. |
Receive Mode |
Two message receiving options are available:
| Batch Size |
In Batch mode, specifies the number of messages to read per batch. |
Partition ID |
(Optional) If specified, the client will receive from this partition only. If empty, the client will receive from all partitions. It is recommended that there is only one active receiver on a partition per consumer group. |
Prefetch Count |
(Optional) The number of messages to prefetch from Azure. Default is 300. |
Starting Position |
(Optional) Start receiving from this event position if there is no checkpoint data for the partition. Checkpoint data will be used if available. Default (empty) is @latest which receives only new events. -1 starts receiving at the beginning of the stream Can be a string, integer or a datetime. |
Starting Position Mode |
Determines whether the starting position is inclusive or not. Default is exclusive. |
Heartbeat
When Action is set to Receive, a heartbeat feature is output through the Heartbeat port after a period of inactivity. The length of this period is determined by the following parameters:
Interval |
The period of inactivity before a heartbeat feature is emitted, in units specified by the Time Unit parameter. Defaults to 1. |
Time Unit |
The unit for Interval.
Defaults to Hours. |
Checkpoint Store (Azure Blob) - Optional
See Parameters - Checkpoint Action for more details.
Container Name |
Connection String |
A connection string to an Azure Storage account. |
Send Options
Payload |
The content of the message. This is often JSON, but can be any string, binary, integer or floating-point value. |
Partition ID |
(Optional) The specific partition ID to send to. If empty, a message will be assigned to a random partition using round-robin. |
Message Properties |
(Optional) Additional properties to send with each message.
Available attributes vary according to the selected Action.
Attributes to Add |
Select any available attributes to be included on the output features:
| Dependencies | Microsoft Azure Account with the Event Hubs Service |
Search for all results about the AzureEventHubsConnector on the FME Community.
