FME Transformers: 2025.0
AWSIoTConnector
Connects to the AWS IoT Core messaging broker. Supports sending (producing) and receiving (consuming) messages.
- Remotely monitor operations for predictive quality and maintenance
- Home automation, home security and monitoring, and home networking
- Commercial traffic monitoring, public safety, and health monitoring
The output of this transformer will vary depending on the action performed. Message data and metadata are presented as feature attributes.
- After a Subscribe action, output features represent messages received from AWS IoT Core.
- After a Publish action, output features represent messages sent to AWS IoT Core.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Endpoint |
The endpoint for connecting to AWS IoT Core. This endpoint has the following format: {account-specific-prefix}-ats.iot.{region}.amazonaws.com |
Root CA Certificate for AWS |
Root CA certificate for AWS IoT Core. Can be found at: |
AWS IoT Client Certificate |
Certificate for client authentication. This can be downloaded after creating a certificate for your device. For more information, see https://docs.aws.amazon.com/iot/latest/developerguide/create-device-certificate.html. |
Client Private Key |
Private key for client authentication. This can be downloaded after creating a certificate for your device. For more information, see https://docs.aws.amazon.com/iot/latest/developerguide/create-device-certificate.html. |
Action |
The type of operation to perform. Choices are:
QoS Level |
The MQTT protocol allows a Quality of Service (QoS) level to be set. The following levels are available:
The QoS guarantees are achieved by performing differing levels of client-server handshake. As a result, higher QoS levels are expected to lower throughput. |
Receive Options
Topic |
The topic to receive from. Topics are usually hierarchical, and can contain the wildcard `#` and `+`. For more information about topic format, please see the following MQTT wiki page: https://github.com/mqtt/mqtt.github.io/wiki/topic_format |
Receive Mode |
Two message receiving options are available:
Batch Size |
In Batch mode, specifies the number of messages to read per batch. |
Send Options
Topic |
The topic to send to. Topics are usually hierarchical, and can contain the wildcard `#` and `+`. For more information about topic format, please see the following MQTT wiki page: https://github.com/mqtt/mqtt.github.io/wiki/topic_format |
Payload |
The content of the message. This is often JSON, but can be any string, binary, integer or floating-point value. |
Attributes to Add |
Select any available attributes to be included on the output features:
| Dependencies | |
| History | Released FME 2019.0 |
Search for all results about the AWSIoTConnector on the FME Community.
