FME Transformers: 2025.0
ArcGISOnlineConnector
Accesses Esri ArcGIS Online or Portal for ArcGIS to upload, manage, update, download, delete, publish, share, or list information about items from an Esri ArcGIS account.
- Manage datasets and supplementary files on ArcGIS Online or Portal for ArcGIS by uploading, downloading, publishing, sharing, and deleting files and folders
- Transfer a file's contents into or out of an attribute in FME
- Read downloaded ArcGIS data using the FeatureReader, or upload data written by the FeatureWriter to ArcGIS Online or Portal for ArcGIS
- Retrieve file and folder names, paths, links and other information from ArcGIS Online or Portal for ArcGIS for use elsewhere in a workspace
Retrieve or update an item’s metadata
The ArcGISOnlineConnector uses either your ArcGIS Online or Portal for ArcGIS account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the file storage service.
Depending on your choice of actions, it will upload or download files, folders, and attributes; list information from the service; share items which already exist in the user’s online content; publish items as feature layers; or delete items from the service. On Uploads, link attributes are added to the output features. On List actions, links and file/folder information are added as attributes.
- This transformer cannot be used to directly move or copy files between different ArcGIS user content folders or locations. However, multiple ArcGISOnlineConnectors can be used to accomplish these tasks.
- Uploading data to ArcGIS is performed via synchronous multipart upload. Each file chunk is 20MB. The connector will upload these chunks consecutively and if a chunk upload fails, the connector will retry each upload up to five times.
- Early termination of translations when performing publish/update/upload actions may result in malformed ArcGIS item entries. (When publishing, a feature service may be created but any title/tags specified for it may not be honored). (When updating/uploading, it is possible for the metadata to be uploaded before the file content has been uploaded).
- The FeatureReader can access online ArcGIS content directly (without using the ArcGISOnlineConnector), however, a local copy of the dataset will not be created.
The output of this transformer will vary depending on the Action performed.
- A Delete action outputs no additional attributes.
- A Download action can save to a file, a folder, or an attribute. If it saves to a file or folder, it will output the path it saved to an attribute.
A Get Details action can retrieve details or metadata for an item. The output feature will have attributes containing metadata values for the item.
- A List action will output a new feature for each file/folder found in the path specified. Each of these new features will have attributes listing various pieces of information about the object.
- A Publish action will output information about the feature service it created, including its id, feature service type and URLs to the feature service itself as well as its ArcGIS content page.
A Set Details action can update the details or metadata file for an item. The output feature will have the id of the updated item and a link to its ArcGIS content page.
- A Share action outputs no additional attributes.
- An Upload action will output the id of the uploaded item and a link to its ArcGIS content page.
- An Update action will output the id of the updated item and a link to its ArcGIS content page.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute describing the category of the error will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
ArcGIS Connection |
Performing operations against an ArcGIS Online or Portal for ArcGIS account requires the use of authentication using a Web Connection. To create an ArcGIS connection, click the 'ArcGIS Connection' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. OAuth: Users can use the `Esri ArcGIS Online OAuth` Web Service to authenticate access to Esri ArcGIS Online sites and the `Esri ArcGIS Enterprise OAuth (Template)` template Web Service to authenticate access to Esri ArcGIS Enterprise sites. Token: Users can also use the `Esri ArcGIS Generate Token` Web Service and login credentials to generate an authentication token. Note: In package version 3.6.0/transformer version 2, support for the old `Esri ArcGIS Online` and `Esri ArcGIS Portal (Template)` web services was removed. Existing web connections can be replaced using the `Esri ArcGIS Online OAuth` and `Esri ArcGIS Enterprise OAuth (Template)` web services. |
Action |
The type of operation to perform. Choices include:
Delete an existing item/folder from a user’s own ArcGIS Online content.
Content Source
Path |
The Item ID of a file or folder on ArcGIS Online or Portal for ArcGIS to delete. If valid credentials have been provided as a web connection, you may browse to a location in the user’s content. The user must be the owner of this item. Notes:
Delete Options
Delete Permanently |
On ArcGIS Online, items can be moved to a recycle bin for 14 days before permanent deletion. The recycle bin is currently only available for ArcGIS online organizations which have enabled this feature. The feature is not available for all item types. For a list of exclusions, see here. If the org site/enterprise installation does not support the Recycle Bin, items will be permanently deleted regardless of this setting. |
Download a file/folder to an attribute/file/folder from a user’s ArcGIS content or a group they have access to.
Content Source
Content Source |
Select the source type of the content to be downloaded
Group ID |
The ArcGIS group which the content is linked to. Note:
Path |
The ArcGIS Item ID of a file or folder to download. If valid credentials have been provided as a web connection, you may browse to a location. Depending on the value of the Content Source parameter, this will list either the contents of the specified group or the user’s own ArcGIS content. Only items which can be downloaded will be displayed. If the user has permission to access items stored in other locations, the id of those items can be manually entered in this field. |
Destination
Download as |
Select whether to store the downloaded data in a File, Folder or Attribute.
Download to Attribute |
Specify the attribute that will store the contents of the downloaded file. Valid for Download as Attribute only. Note FME will attempt to convert the attribute's contents to a UTF-8 string. If this fails, the attribute's contents will be created as raw binary. To ensure that the original bytes are always preserved and never converted to UTF-8, use Download as File instead.
Download to Folder |
Specify the path to the folder that will store the downloaded file. Valid for Download as File or Folder. |
If File Exists |
Whether to overwrite existing files in the target destination. Valid for Download as File or Folder. |
Include Subfolders |
Whether to include subfolders when downloading a folder. Due to the way that ArcGIS content is structured, only the root folder contains subfolders. Valid for Download as Folder . |
Get details for an item, including its metadata.xml file.
Content Source
Content Source |
Select the source type of the content to be listed
Group ID |
The ArcGIS group which the content is linked to. |
Path |
The Item ID of a file on ArcGIS Online or Portal for ArcGIS to retrieve metadata for. If valid credentials have been provided as a web connection, you may browse to a location in the user’s content. |
List the item details for the contents of a group, a user’s folder, a user’s root folder, or all of a user’s content.
Content Source
Content Source |
Group ID |
User Content Folder |
The ArcGIS folder ID to list the contents of, or ‘/’ for root. If valid credentials have been provided as a web connection, you may browse to a location in the user’s content. Only folders may be selected. Valid when Content Source is set to User. |
Whether to include subfolder content when listing. Due to the way that ArcGIS content is structured, only the root folder contains subfolders. Valid when Content Source is set to User. |
Publish an existing ArcGIS item as a feature service. ArcGIS item types which the connector supports for publish:
- Shapefile
- CSV
- Microsoft Excel
- Feature Collection
- GeoJson
- File Geodatabase
- Scene Package
- SQLite Geodatabase
- Image Collection
- Service Definition
- Tile Package
- Compact Tile Package
- Vector Tile Package
Extra Usage Notes for Publish:
- csv/excel files will be analyzed and have some publishing parameters autogenerated for them. The generated publishing parameters will be logged at the info level.
- For CSV files, ArcGIS will attempt to classify the file as containing either coordinate data, address data, lookup data, or no location data. If the CSV file is classified as having location data but ArcGIS cannot determine the relevant fields containing this data, the ArcGISOnlineConnector will log a warning and publish the CSV file as though it does not contain any location data. The resulting feature service will be a table.
Publishing Options
Content Source |
The Item ID of a stored ArcGIS file to publish. If valid credentials have been provided as a web connection, you may browse to a location in the user’s content. Only publishable items should be displayed in the browser. The user must be the owner of this item. Note:
Feature Layer Title |
The name to set for the newly created feature layer in ArcGIS. If this is left blank, the published item will use the existing title of the source item. Note:
Feature Layer Tags |
The tags that the published feature layer should have in ArcGIS. If this is left blank, it published item will have the existing tags of the source item. |
Coordinate System |
Specify the target spatial reference of the created feature service. If not specified, this will default to WKID 102100. |
Wait Behavior
Wait for Publish Processing |
Whether to wait for the feature service created to publish
Processing Timeout (s) |
The amount of time (seconds) to wait for the feature layer to publish. If not specified, this will default to 180 seconds. |
Update the details for an item or overwrite its metadata.xml file.
Content Source
Path |
The Item ID of a file on ArcGIS Online or Portal for ArcGIS to update metadata for. In order to successfully update the metadata, the user must own the item being updated. If valid credentials have been provided as a web connection, you may browse to a location in the user’s content. |
Details
Operation |
Select the operation to perform.
XML Metadata Attribute |
The attribute that contains XML content to upload as a metadata file. This parameter is only enabled if Operation is set to Replace Metadata XML. |
Fields
If a field is left blank, it will not be updated on the item. If it is set to NULL, the field will be cleared.
Title |
Specify a new title for the target item. |
Tags |
Specify new tags for the target item. Tags should be provided as a comma separated list. |
Summary |
Specify a new summary for the target item. |
Description |
Specify a new description for the target item. |
Credits |
Specify new attribution information for the target item as well as its copyright status. |
Access and Use Constraints |
Specify new license information or use restrictions for the target item. |
Type Keywords |
Specify new type keywords for the target item. Type keywords should be provided as a comma separated list. Note that updating this value only updates user-defined type keywords. Keywords associated with the ArcGIS Item Type will still remain. |
Thumbnail URL |
Set a new thumbnail for the target item. This should be provided using a URL to the image. |
Extent |
Set the bounding box for an item. Coordinates should be in WGS84 and must be provided in the form minX, minY,maxX, maxY. |
Change the sharing level of a user’s ArcGIS Online content item or share it to additional groups.
Content Source
Path |
The Item ID of an ArcGIS file to share. If valid credentials have been provided as a web connection, you may browse to a location in the user’s content. |
Sharing
Share Level |
Specify the sharing level to set for the item.
Share to Additional Groups |
Select additional groups to share the item to. If there is a valid web connection, a list of all the groups the user belongs to will be displayed. Groups are listed with space separated IDs. Notes:
Update the data stored for an existing ArcGIS item and optionally specify new title/tags for that item.
Content Source
Path |
The Item ID of an ArcGIS file or folder to update. If valid credentials have been provided as a web connection, you may browse to a location in the user’s content. Only items which have data that can be updated by the connector will be displayed. If the user has permission to access items stored in other locations, the id of those items can be manually entered in this field. |
Data Source
Upload |
The type of data to update with.
When working with large objects, File is a better choice than Attribute as the data will be streamed directly from disk and not require that the object be stored entirely in memory on a feature. |
File to Upload |
The file to be uploaded to ArcGIS. Valid if Uploading from File. The file type (file extension) must match that of the target update item, otherwise the feature will be rejected. |
Attribute to Upload as File |
The attribute to upload data from. Valid if Uploading from Attribute. |
Metadata
Title |
Specify a new title for the target item. If this is left blank, the title will not change. |
Tags |
Specify new tags for the target item. If this is left blank, the tags will not change. Tags should be provided as a comma separated list. |
Upload a file or attribute to a location in a user’s ArcGIS Content
Data Source
Upload |
The type of data to be uploaded.
File to Upload |
The file to be uploaded to an ArcGIS account. Valid if Uploading from File. |
URL |
The URL of the item to be submitted. This can link to a service, a web mapping application, or any other content accessible at the specified URL. Valid if Uploading from URL. |
Metadata
Title |
The name to set for the uploaded item. |
Item Type |
The ArcGIS item type that the uploaded file should have. Notes:
URL Item Type |
For a list of types of layers available to Map Viewer using a URL, see Add layers from a URL. This transformer does not support these types: ArcGIS Server web service, OGC Feature Layer, and GeoJSON. |
Tags |
Specify tags for the created item. Tags should be provided as a comma separated list. |
Content Destination
The ArcGIS folder ID to upload to. The name of a user’s ArcGIS Folder can also be used, provided that it does not conflict with the ID of an existing folder. If no such folder exists, one with that name will be created. If valid credentials have been provided as a web connection, you may browse to a location in the user’s content. Only folders may be selected. Note:
Upload with File Name |
The name of the file created from the data supplied in Attribute to Upload as File. The name must include a filename extension (for example, .csv, .jpg, .zip). |
Available attributes vary according to the selected Action.
Attributes to Add |
Select any available attributes to be included on the output features:
| Dependencies | Esri Access |
| Aliases | AGOLConnector ArcGISPortalConnector |
| History | Released FME 2020.1 |
Search for all results about the ArcGISOnlineConnector on the FME Community.
